Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-28-2014, 09:34 PM
Pigman54 Pigman54 is offline
Pigman54 is starting off with a positive reputation.
Sidewalls are starting to split
Hey guys, a little less than a month ago I got a 4 inch lift, 35x12.5x20 Mickey Thompson ATZ's, and Moto Metal 20x12's. I was underneath the truck earlier today and glanced at the backside of one of my tires and noticed a 4-5" cut in the sidewall. I checked the backside of every tire and each of them had similar cuts. If the cuts would've been continuous they would have made a perfect circle around the sidewall. Only two of the tires so far have cuts on the outside but all of them have cuts on the inside.
I immediately took the truck to my local Discount Tire to have someone with more experience look at it. They told me that my tires are a Load Range E2 which has a max of 65 psi. My truck calls for 55 PSI front and 80 PSI rear. They said my current E2 tires can't handle the weight of the truck and that I need tires with a Load Range E1 that can be aired up to 80 PSI.
All my tires were inflated to 65 PSI and they told me to drop it down to 55 front and 60 rear to help relieve some of that pressure. They said for right now it is only cosmetic damage and I shouldn't worry about it but that I should look into getting Load Range E1 tires in the very near future.
Can anyone confirm that what the guy at Discount said is true? Or was he incorrect? What I'm having trouble understanding is that I see guys with diesel trucks all the time that have the same size tires as me and don't have any issues with their tires not being able to handle the weight of their trucks. If someone can help me make sense of this, please do. I will get pictures of the cuts tomorrow.
Thanks,
Josh
__________________
2003 F350 CCLB 4X4 XLT 7.3 280k - Zone 4" lift installed by Full Flex Customs, Nitto Trail Grappler 35x12.5x20s, Moto Metal 962 20x12's, BTS trans w/ 6.0 cooler, Diamond Eye 4" exhaust, stock intake, DP F5, Autometer boost & pyro, HPx, F650 dash mod, stock turbo, Tough Country Deluxe front and rear bumpers, Spyder headlights, and damn PMR's!
Old 07-28-2014, 10:22 PM
crop harvester crop harvester is offline
crop harvester has a good reputation on FTE.crop harvester has a good reputation on FTE.
as long as your staying in the range of weight marked on your side walls,then your tire choice is not your problem,but I cant get away with those tires due to slide in camper.
__________________
01 F350 PSD LARIAT CC SB SRW 4X4 4R100 218K 373 GEARS,265/75R16 TOYO OPEN COUNTRY,HUTCH&HARPOON,PREPUMP FUEL FILTER,4" EXHAUST,AIS, COOLANT FILTER,[ ISSPRO PERFORMAX GAUGES TRANY,BOOST,EGT ] AIRBAGS,STABLE LOADS,SUPER HITCH,RS9000 SHOCKS,ODDESSY BATTERIES,NIPPON G-REDUCTION STARTER,PARTS ON BENCH FRX,HPX.
Old 07-28-2014, 10:38 PM
greg_8507 greg_8507 is offline
greg_8507 is starting off with a positive reputation.
Did you get the tires from the same place you took it back too? I wonder if you actually got a set of tires that were not properly stored and are a few years old. Some off road shops and tire shops are bad about installing tires that are really old, but have never been installed. I don't know if there is any regulation against it, but it can leave you with what seems as premature dry rot. But it really isn't so premature if the tires have been sitting on a rack in the weather for the last 3 years.
Old 07-28-2014, 11:00 PM
Sorry I forgot to mention that I bought them used from an acquaintance of mine. He was the second owner of them and only sold them because he got a bigger lift and therefore needed bigger tires. He said after he took them off they sat in his garage for about 3 months.
__________________
Old 07-28-2014, 11:01 PM
If I remember correctly, the DOT on them is May of 2012.
__________________
Old 07-28-2014, 11:08 PM
SARDiverDan's Avatar
SARDiverDan SARDiverDan is offline
SARDiverDan has a very good reputation on FTE.SARDiverDan has a very good reputation on FTE.SARDiverDan has a very good reputation on FTE.SARDiverDan has a very good reputation on FTE.
Tell your tire guy he does not know what he is talking about. Load range E1 tires are usually an 80psi tire and an E2 comes in around 65psi: however, the E2 tire is designed to hold the same weight ratio of the E1 tire because its wider and distributes the weight to carry the load. If you have brand new MT tires and they are splitting in less than a month I would be demanding replacements (cosmetic my ***). I use to run BFG's and they would start showing side wall splitting at around 25k so I went with Pro Comps and I have not had any splitting issues. Splitting can also be caused by not driving the tires and they dry out just sitting around but yours are brand new and should not be splitting IMHO. Now are these splits slight lines in the rubber or cracks you can put your fingernail in? Just FYI, my tires are rated to 50PSI cold and I run them at 48 psi.
EDIT: After I posted I see the others that got in before me. I know some would just drive on them until they got bad but I would be looking at getting them replaced soon
EDITx2 - replacing those tires will run you somewhere between 1,600-2,000 depending upon what you want
__________________
02 F250 4X4 7.3, PC 6 ˝ lift, Centerline wheels, PC 37x12.50R-17's, Warn PP HD Winch, Jotto Console, Scanner, Icom HAM radio, 91 Gal. Aux fuel cell, Diamondback HD bed cover, Warn Hubs, dual steering stab, Step2 Bed steps, Warn FF, AIS, 4" t/b exhaust with Aero turbine muffler, backup buddy lights, Mag-Hytec diff cover & tranny pan, SGII, 6.0 T Cooler, ELF7405 with oil By-Pass, IH bellowed ups, Gen 2 FRx, HPx, CCV Mod, CAT ELC, ez down t-gate, Fumoto drain, Rev/Cargo LEDs, 4 pillar gauge with ISSPRO, DP Tuner
Old 07-28-2014, 11:31 PM
SARDiverDan - These are cracks that I can put my fingernail in; not just weather cracking. I have been looking at Toyo M/T's and Nitto Trail Grapplers. I was kind of confused because the guy at Discount told me I could go with the Toyos but I looked them up when I got home and they also had a max PSI of 65. I also work at Discount Tire so I can get the Toyos for right under $1600.
So I'm guessing I shouldn't sell these tires after I get new ones as these are no good, correct? Or would they possibly be okay to use on a lighter truck? I'd really like to get some money out of them but unlike a lot of people in our world today, I have morals and could not live with myself if I sold potentially dangerous tires to someone. If you think these are no good to sell please let me know. Thank you for your help.
__________________
Old 07-29-2014, 12:42 AM
Don't get hung up on the psi rating as each tire is different. While stock tires may be filled to higher PSI, larger AT or MT tires are usually much lower PSI rating but that does not mean they can't be used on the truck. Load range E is load range E regardless of how much air is in them from one manufacturer to another, just fill them to the tire specs, not what is printed on the door panel of the truck. Like I said, I run 48 psi in my 37's and they have a max psi of 50 cold and I carry all kinds of stuff, even a cord and half of wood does not squash them down a bit
You might be able to sell them to somebody that either needs tires badly and can't afford any or someone may buy them as a strictly off-road tire and will use them until they fail. I don't like going down the highway at 70-75 mph with tires that are splitting to the point they need replaced. Having a blowout on 35's is a lot different than stock tires at stock height.
__________________
Old 07-29-2014, 01:22 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
My tire lawyer buddy could give you a list of names of dead people who bought used tires.
Unless you know someone who will only use them on a farm or short off road use, use a hole saw through the sidewall when you pull them.
It's not just the guy in the vehicle with the blowout who eats %^&* when there is a blowout. Think about your family driving next to him or meeting him in a curve when it happens.
Old 07-29-2014, 08:50 AM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
why so much air?
i run 55 lbs front and 30 rear on my 02 diesel.
i run a chalk line across the tire, then drive it easy around the block.
look at the tire and see where the chalk line is wore off and where it is not.
wore off the edges but not the center is not enough air.
wore off the center but not the edges is too much air.
wore completely off is proper air.
__________________
Tom
Moderator of the "not wrapped too tight forum"
rarely in life do you meet a person that will drop everything to help a stranger,
and give the shirt off his back to a friend.
Steve Price was that kind of person.
Godspeed "window licker", the short bus will never be the same with you gone.
Old 07-29-2014, 02:23 PM
Here are some pictures. I checked the DOT and it's the 51st week of 2012, so right over a year and a half old.
__________________
Similar Threads
Tire PSI sensor shows low preasure itry2fly Super Duty & Heavy Duty 22 01-10-2013 08:29 PM
Tire pressure monitor system jollybear Super Duty & Heavy Duty 54 11-18-2012 05:13 PM
Tire/Wheel Question roos3342 1999 - 2003 7.3L Power Stroke Diesel 3 04-22-2008 07:47 PM
tire PSI-new LT235-85-R16 tires fjlee Super Duty & Heavy Duty 1 11-27-2007 06:11 PM
Would Helo Maxx 6 18x9 and Mickey Thompson Baja ATZ 325/60 R18 Fit??? neveraseven 2004 - 2008 F150 4 08-16-2005 08:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
