Order guide - Ford Truck Enthusiasts Forums
2015+ F150 Discuss the 2015 Ford F150
Order guide
Old 07-28-2014, 09:18 PM
swanee swanee is offline
swanee is gaining momentum as a positive member of FTE.
Order guide
Hope this works, found this on f150 ecoboost.net by a fella named Trek. http://www.f150ecoboost.net/forum/at...rder_guide.pdf
Old 07-29-2014, 01:24 PM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
If I'm reading all this correctly, the STX and FX trim models are gone as stand alone trim levels. Like on the superduty trucks, the FX packages will be available as an option. I can see a ton of FX buyers getting pretty mad about this.
Old 07-29-2014, 02:21 PM
paredneck33's Avatar
paredneck33 paredneck33 is offline
paredneck33 is a splendid one to beholdparedneck33 is a splendid one to beholdparedneck33 is a splendid one to beholdparedneck33 is a splendid one to beholdparedneck33 is a splendid one to beholdparedneck33 is a splendid one to beholdparedneck33 is a splendid one to behold
Well that's how the fx packages started out to begin with. It was an off road add on package that got you the rancho shocks, skid plates and I think if I remember correctly and added 1" of ground clearance.
Old 07-29-2014, 06:39 PM
msalyer msalyer is offline
msalyer is gaining momentum as a positive member of FTE.msalyer is gaining momentum as a positive member of FTE.
The HD payload pkg. only gives a 7850 GVRW as opposed to 8200 on mine. Payload may still be higher due to the weight loss?
Old 07-29-2014, 08:57 PM
As a six time Xl owner I am excited to finally get 40 console 40 seats instead of the traditional seats with the big, useless armrest. Also the elimination of the stick transfer case and four speakers for free are just icing on the cake.
Old 07-29-2014, 11:05 PM
Quote:
I personally prefer the "stick" transfer case. More speakers are never a bad thing though.
Old 07-30-2014, 12:27 PM
n2umr n2umr is offline
n2umr is gaining momentum as a positive member of FTE.n2umr is gaining momentum as a positive member of FTE.
Sucks you can't get the 2.7 in the 157" WB with 4x4. Looks like I'm getting another 3.5.
Mark
Old 07-30-2014, 08:51 PM
It's no so much the stick, but the cup holder that comes with it on the hump, nobody can sit in the middle.
Old 07-31-2014, 07:25 AM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Interesting. Seems the GVWRs are less, but it would appear that the payload ratings are slightly higher than before because of the lighter weight.
I've attached the order guide so the link doesn't disappear.
Old 07-31-2014, 10:22 AM
Yeah on would think that the GVWR would stay the same given the increased payload rating. What about the GCWR has that dropped as well?
Old 07-31-2014, 01:30 PM
This is figuring the HD payload using my truck as an example, its Gvrw is 8200, truck left the factory weighing 5972 leaving a payload of 2228. An equivalent 2015 the Gvrw is 350 lbs less (7850) but the truck is said to weigh 700+ less. Therefore I would expect the payload to be ~350 lbs more. So around a 2578 payload would be my guess. That 's a nice payload for a half ton truck.
Old 08-19-2014, 10:47 PM
Ancona Ancona is offline
Ancona is starting off with a positive reputation.
I looked up the GVWR/payload for my 4.2L regular cab '04 Heritage for comparison. Its GVWR is 6,050 and payload 2,060. Curb weight 3,990.
For a '15 regular cab (from the link) the GVWR is 6,010 and 3.5L payload is 1,910. 2.7L Ecoboost payload is 1,800. Curb weight not listed, but using basic math its 4,100 for the 3.5L and 4,210 for the 2.7L Ecoboost.
Seems like the big aluminum weight saving brings them close to the '97-'03 ('04 Heritage) GVWR with less payload and more curb weight, at least in this 4x2 regular cab example.
2016 F150 Order guide?? HeavyAssault 2015+ F150 5 10-06-2016 09:08 PM
79 ford f150 timing chain guides brandan123 1973 - 1979 F-100 & Larger F-Series Trucks 5 08-08-2016 08:32 PM
Did You Know Two-Thirds of New F-150s Sold are EcoBoost? edtahaney 2015+ F150 22 06-06-2015 07:04 AM
Ecoboost Fastfreddiey Performance & General Engine Building 1 06-12-2014 07:49 PM
2012 SD Order Guide kmonty2 6.2L V8 8 08-01-2011 06:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
