302 is a dog
Good idea on the cheap stuff. And if the PO responds ask him what cam he went with. That could tell us a lot.
The GM dizzy requires a very good connection to power. Many guys have tried to use the stock wiring but that won't work due to the ballast resistor that's hidden in it. So make sure you have a large wire going to a good source of power, such as a relay near the battery.
Edit: I'm assuming a stock bore 351 won't suffice? What would be a magic number to have it punched out to?
Be aware that aluminum heads can run between .5 and 1.0 more compression than cast iron heads can without pinging. Or, to put it another way, aluminum heads wick heat away so rapidly that you have to run more compression to get the same power. In any event, you need to think about your target compression ratio as you plan the engine.
If you want to do any hot rodding to it, stroking it would be the best bang for the buck if you have the money. That will naturally raise your compression too.
Lots to think about when building a engine like this.
I'm building a 400 that will be running Trick Flow heads. The target CR is 10.5:1 and it is supposed to run fine on 87 octane, although I won't go to the bank with that quite yet. And it is expected to put out over 500 ft-lbs at low RPM. In fact, the 550 HP is at 5500 RPM so it won't need to wind up to give power.
And that's the key for a truck or something going off-road - torque at low rev's. Which is why a 302 isn't a good as a 351W because the stroke is so short that it can't give the low-rev grunt.
351w long block bored .040 over
Just found this while browsing. Seems like a cheap starting point and I can use all my go fast stuff on it.
So it would be better to start with a fresh stock block? I'm trying to keep this truck as cheap as possible, so I don't plan on building a high dollar stroker kit right away.
#28
#30
