New rotors/pads, constant squealing
I've replaced the pads and rotors on my 97 f250 HD, only to have constant squealing. I've replaced ranger rotors before with no problem but this has been an adventure haha. It's squeals constantly up to 35, (I've only went up to 35) and squeals louder under braking. Just looking for some pointers. Probably just need a good cleaning, but wanted to know if anyone else has experienced this. The truck is parked until its fixed more than likely. Thanks in advance!
I depends on what quality parts you used? You can chaffer the pads meaning take I file and bevel the front and rear of pads on a slight angel. You can also use brake quit, it's a glue like compound you put on the back of pads like a glue.
Did you replace the rotors? Sometime just taking the truck out and pound the **** out of the pads can help. They can get glazed
Hope this helps
Hope this helps
Hope this helps
Hope this helps
