97 F350 Power Problems - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-28-2014, 07:29 PM
cnhtech cnhtech is offline
cnhtech is starting off with a positive reputation.
Question 97 F350 Power Problems
Hey guys I've got a 1997 F350 with a 7.3 Direct Injection Powerstroke and 5 speed transmission, 2 wd, with 4.10 gears. With no trailer on it, it moves pretty good, but the minute I put our enclosed trailer behind it, it turns into a gutless pos !!! Trailer loaded weights in the 12-14k range. If I hit a hill of any kind of size, I better be going 65+ and turning 2500 or better to have any chance of holding that speed by the top of the hill. I have also noticed on my last trip, which was 2 hours long, that when I got home the passenger side floor board / trans tunnel area was very warm, I had a pair of jeans laying on floor and when I picked them up it felt like they just came out of the dryer.
You guys got any wisdom as to what my problem might be?
The truck is my father in laws, is completely stock, is showing 149,000 on the clock. He got it with around 75,000 on it and has only had to do regular maintence to it ( oil and fuel filter changes).
Old 07-28-2014, 11:11 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Quote:
First of all, welcome to FTE. If your trailer weighs that much and you can hold that speed to the top, your doing great!! These engines are gutless stock, so don't expect to much. You can read in my signature and look at what I pull along with my mods and I struggle at times. Mine is about 18.5K and its running great. Downshift a lot and keep the RPM's up and you will do fine. If you don't believe what I'm saying, try that with a gasser!!
Old 07-28-2014, 11:24 PM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
After a run crawl under and feel if the trany is warm. It might be low on fluid. Or maybe exhaust leak around there? Check your uppipes. And like Glenn said, these trucks stock dont have much power. A intake, exhaust will let it breath a little better.
Old 07-29-2014, 07:58 PM
I crawled under it last night and noticed it had a muffler towards the rear and what I guess would be a catylitic converter closer to the front. Is this "converter" a known problem? Like I said in the original post, with out the trailer it seems fine. If it was a gasser, it acts to me like an exhaugst restriction like a converter being plugged up.
Old 07-29-2014, 09:28 PM
A lot of us get rid of the cat and muffer, even take all the exhaust off and go with 3" DP, 4" straight pipe exhaust. Then put on a 6637 or AFE air filter and let that baby breath. That's the first thing to do and after that we can spend all your money, LOL!!
Old 07-29-2014, 09:40 PM
Another question, why is the exhaust pipe, down pipe I think it's called, flat? Seems to me that would restrict exhaugst flow? What's is this 6637 your referring too?
Old 07-29-2014, 10:08 PM
Ford shoe horned the PSD into our year of trucks, thus the flat pipe. You are 100% correct, its very restrictive. Get rid of it with a sawzal, not a torch. A 6637 is a open air filter, look on Riffraff Diesel Performance link at the top of the page under sponsors.
Old 07-30-2014, 11:07 AM
cowmilker08's Avatar
cowmilker08 cowmilker08 is offline
cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.
I agree with Glenn. You'd be surprised how much those 2 mods help. I would also gut the exhaust back pressure valve while changing the downpipe if it were me.
Old 07-30-2014, 07:30 PM
Where's this exhaust back pressure valve at ?
Old 07-30-2014, 08:03 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
between the turbo and the downpipe
Old 08-31-2014, 12:32 AM
jrods2 jrods2 is offline
jrods2 is starting off with a positive reputation.
wait a minuet, gut the back pressure valve? I thought the bpv was to stop the tubo from lag.
Old 08-31-2014, 12:46 AM
Quote:
ebpv is to cause back pressure to make the motor work harder when it is cold. This helps it to warm up faster.
FI460's Avatar
FI460 FI460 is offline
FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.
Nope. It's just a warm up valve that's effectiveness has been questioned.
Old 09-02-2014, 12:16 PM
To add to the above posts, it increases turbo lag. Gutting it will reduce turbo lag.
Old 09-02-2014, 02:57 PM
jchosler's Avatar
jchosler jchosler is offline
jchosler is starting off with a positive reputation.
Intake, exhaust,and gauges are always your first mods on these OBS's. after there are a few mods that really wake them up. IMO chip, fuel, and injectors. A lot of guys are happy with just adding a chip if you dont want to really start getting into it.
E40D, Heavy Tow Load, Won't accelerate forward after stopping on hill. thebaldguy1369 Clutch, Transmission, Differential, Axle & Transfer Case 0 02-25-2016 04:57 PM
MPG from long haul (3,300 miles) with trailer iggy2 6.2L V8 17 07-25-2015 01:02 AM
Are my expectations too high? breedo99 1994.5 - 1997 7.3L Power Stroke Diesel 66 06-23-2015 01:13 PM
82 f250 300 single barrel losing power intensity47 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 05-31-2015 05:31 PM
Where's 1st gear 99f350sd 1999 to 2016 Super Duty 19 02-22-2015 03:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
