Long crank with warm engine
I have a 75 F250 with a mild built 460. When I start the truck after sitting/cold start. It cranks and fires up immediately. After driving and the engine is at normal operating temperature, I can turn it off, try to start it again right away but have to have the gas pedal to the floor while cranking for 5-6 seconds. Once it starts, it does not sputter, idle rough or die. Same thing applies if I wait for say 30 minutes or so and the engine is still warm...long crank time.
It always runs great, idles smooth, and has excellent acceleration. I do notice that after I have been driving and I park it, there is a smell of gas which will disappear after a while. No leaks, anywhere. Not around the carb, fuel lines, fuel pump, filter, tank...nothing.
Not sure if it is related or not, but...if I start it cold, it has a normal fast idle. If I tap the gas pedal, it drops down to about 650 rpms which is close to a "normal" idle speed. After I drive it and it warms up, the idle in neutral is about 750 rpms.
It has an Edelbrock 1406 carb with larger secondary jets (I had it done at a shop - don't remember what size they are).
Am I getting too much fuel in the carb once it warms up? Is this a symptom of the choke not opening up all the way? Looking for some direction on where to start to find the cause.
Thanks.
Thanks.
Common carb issue, however the cause is often different between types.
Myfreeford, edelbrock carb on an aluminum manifold? Just a gasket between the manifold and the carb? If yes, get a heat sink between the two. One of those thick gaskets, a phenolic spacer, something like that. I don't recommend the ones that are a pile of plates and gaskets they tend to break carbs.
Secondly double check float level.
On the holley is tends to be a power valve + high float level issue
I agree, your carb is percolating into the intake.
This is why you smell gas but don't see any.
Then you have to hold the throttle wide open to clear the flooding.
A spacer can help.
So can a heat shield (an aluminum reflector plate that bolts under the carb)
These things haven't been common since the early days of emissions mandates and subsequent skyrocketing under hood temperatures.
I'm old enough to remember those nightmares.
A spacer can help.
Honestly, I don't know what kind of spacer I want/need. I've never knowingly needed one. I have an Edelbrock 1406 and a Performer 460 manifold. I am not familiar with which material is better for this kind of issue.
Do I need to use an Edelbrock spacer? What material will perform the best? As for thickness, is it better go go thicker?
Given that it's a truck I would assume four bore or divided plenum depending on what intake manifold you have.
In which case I only see 1/2" wood from Edelbrock but they do have four hole in 1" phenolic.
There are plenty of other manufacturers.
Separation is going to help torque by keeping velocity up at part throttle.
Edelbrock Carburetor Spacers - Wood Design - Free Shipping on All Orders @ JEGS
http://www.jegs.com/webapp/wcs/store...enolic+spacers
dustinlauricha
06-06-2010 01:40 PM
1985ColumbusF150
10-23-2004 02:00 PM
