02 7.3 in a 96 f250 crew gasser? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-27-2014, 11:26 PM
DanielT28's Avatar
DanielT28 DanielT28 is offline
DanielT28 is starting off with a positive reputation.
I have a wrecked 02. 7.3 auto. Brother in law wants to buy it and put it in his 96 f250 crew gasser. Is it worth it ? And Is it possible ? Both are auto
Old 07-27-2014, 11:40 PM
BruteFord BruteFord is offline
BruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud of
By far the largest obstacle is the law.
Old 07-27-2014, 11:52 PM
williameub williameub is offline
williameub is starting off with a positive reputation.
Is it possible? Yes.
Is it worth it? Maybe. Most likely no. But maybe.
The 7.3 will fit fine. The trans... I don't know. I've never read of anyone fitting a 4R100 into an OBS.
Just some things to think about though.
Drive shafts will have to be modified.
You'll have to goto an e-fuel setup.
The wiring.
Front suspension may need to be beefed up depending in if the OBS has a sb or not.
Radiator differences
Plumbing and modifications for an intercooler.
Ect.
Old 07-28-2014, 12:18 AM
DanielT28's Avatar
Ya. It's up to him. Just thought I'd see what kind of input I'd get
Old 07-28-2014, 12:22 AM
Robbieo11's Avatar
Robbieo11 Robbieo11 is offline
Robbieo11 is starting off with a positive reputation.
Law is a big thing here in ny. They have to plug in gassers for emission check if vin is tagged as a gasser it has to be. So that would screw the program here. Just a hint find a 95 and do it to that
Old 07-28-2014, 01:19 AM
Quote:
All I have to say is, if he's got the money to spend and really want it. Go for it (that is if Uncle Sam isn't on your back about it.).
I think it sounds like a cool project.
Old 07-28-2014, 05:20 AM
DanielT28's Avatar
Washington state here. We're not in the big city. No emission testing here
Old 07-28-2014, 10:06 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Quote:
I have. The 4R100 is exactly the same size as the E4OD. The 4R100 is actually a modified E4OD.
The 4R100 will have to come with the 7.3L. The E4OD in the truck now won't bolt to the diesel. Also take the computer and all the wiring from the donor truck.
This swap is not too difficult when there is a donor truck to get all the parts.
Old 07-28-2014, 11:15 AM
DanielT28's Avatar
Hmmm. We'll that's good to know. Donor truck has all parts. Just wasn't sure about cross members and stuff
Old 07-28-2014, 11:42 AM
jchosler's Avatar
jchosler jchosler is offline
jchosler is starting off with a positive reputation.
Its hard to say about the crossmembers but Im sure you'll need to modify them or drill new holes into the frame, I really doubt it'll bolt up without modification. E-fuel is another project in its own, you can buy a setup for a grand or more or piece one together, it would be very conveniant to get that done with the motor out of the truck.
Old 07-28-2014, 11:56 AM
FI460's Avatar
FI460 FI460 is offline
FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.
02 has electric fuel?
Old 07-28-2014, 12:13 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
Quote:
Yep
You could just transfer the fuel system from the sd over
Old 07-28-2014, 12:31 PM
tshrager's Avatar
tshrager tshrager is offline
tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.tshrager has a good reputation on FTE.
E fuel with a fuel bowl...
Old 07-28-2014, 01:48 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
In cab wiring will be a nightmare
Old 07-28-2014, 05:29 PM
Quote:
Originally Posted by Mark Kovalsky View Post
I have. The 4R100 is exactly the same size as the E4OD. The 4R100 is actually a modified E4OD. The 4R100 will have to come with the 7.3L. The E4OD in the truck now won't bolt to the diesel. Also take the computer and all the wiring from the donor truck. This swap is not too difficult when there is a donor truck to get all the parts.
Fantastic! I didn't know this! Thanks!
SoCal nu b Alyupe11 New Member Introductions 1 08-29-2016 03:36 PM
2006 F250 gasser 7.3 swap possible? str$ke-it 1999 to 2016 Super Duty 12 08-02-2016 02:17 PM
Roof Crew has nice taste in work trucks phoskins 1987 - 1996 F150 & Larger F-Series Trucks 7 08-08-2014 11:17 AM
Radiator support help Hunter7.3 1994.5 - 1997 7.3L Power Stroke Diesel 16 08-28-2012 11:04 PM
another wrecked F250 tommypic 1999 to 2016 Super Duty 16 08-13-2009 01:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
