brake light issue
brake light issue
hey fte guys im having a problem with brake lights they dont work tried everything so far ive replaced a couple of fuses pedal switch and the bulbs for good measure any other thoughts 04 super duty 6.0 and alittle back story not sure if related i tapped into the over head lie o meter to run my radar detector and gps and the other day i noticed that wires going to the unhooked radar dectector where melted together and the fused poped so unhooked all of that replaced the fuse and the lie o meter came back online but still no brake lights anybody have the wiring digram or something to work with anything would be help i did a search with no luck thanks again
Sigh Did you check the nearly 20 feet 0f wireing between the cab and the rear of the truck? Did you check the 3 connectors at the back and their sub harnesses?
When you checked the fuses ford uses 2 for the brakes right and left and seperate ones for turn signals.
A quick google search came up with 9 different diagrams.
Seanlee13
10-02-2010 10:31 AM
Caplax40
1983 - 2012 Ranger & B-Series
12-16-2007 12:07 PM
turbocoupe5.0
02-26-2007 04:36 PM
