Distributor issues - Ford Truck Enthusiasts Forums
Distributor issues
Old 07-27-2014, 10:00 PM
70f250highboy's Avatar
70f250highboy 70f250highboy is offline
70f250highboy is starting off with a positive reputation.
Distributor issues
Hey so Ive got a 79 Bronco with a 85 351W swapped in. It was a rebuilt motor (from a prof. shop) when I got it in 2012 or so and swapped it in. Since about Last summer I have started shearing the cam gear pin on the distributor. In the last three months or less I've gone through about 8 including the gear itself being ground down. I originally had an HEI distributor which I replaced with a stock brand new Ford, and it still did it. Then replaced the gear with a bronze gear and it still did it. Then replaced the oil pump and pickup tube and it still did it. Doesn't matter if I'm driving up hill down hill or idling it will still shear a pin almost every two days. Oil pressure reads about 45-60 so I don't think the cam is seizing but I have run out of ideas. Anyone got any clue? If i can't get it right motor and trans are coming out and being set on fire Any help would be greatly appreciated
Old 07-28-2014, 12:38 AM
Torky2 Torky2 is offline
Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.
Since shearing the pin is most likely caused by excessive loading, any chance that you have a dimensional issue with oil pump drive or distributor itself? Like something too long and getting jammed down, such that it will turn only with a lot of effort?
It's not like you can just turn something by hand to check when it is installed, so other than some critical measurements against a standard, or other known-correct parts to swap in and try, I don't have any bright ideas.
Old 07-28-2014, 10:29 AM
I had one issue with the pump driveshaft where it was bent at a 45 about an inch and a half from the bottom but replaced it and it fits down in nicely with no struggles
Old 07-28-2014, 10:40 AM
David7.3's Avatar
David7.3 David7.3 is offline
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
To shear that pin, it takes some power, cant see it being anything with the distributor. Since you did the oil pump and shaft, what's left? Is the cam walking? I know of people who had to use a cam button (little bronze spacer that holds the cam against the cover, I can see that happening. What bent the first oil drive rod? Can the cam have a defect when they machined the drive for the distributor. Let me ask around and see if anyone in the shop has had a problem like this.
Old 07-28-2014, 02:21 PM
I haven't messed with the cam at all. If it came to doing that I'd just as soon replace the motor. It's always had issues since I got it from the rebuild shop and they refuse to warranty it
Engine will turn over but wont start. Firefighter6601 1987 - 1996 F150 & Larger F-Series Trucks 13 02-07-2016 05:17 PM
1968 Ford F100 Timing Chain Replacement & Tolerances Johnnynobody 1967 - 1972 F-100 & Larger F-Series Trucks 7 01-25-2016 07:36 PM
Distributor help!!! Ed2 1987 - 1996 F150 & Larger F-Series Trucks 4 08-20-2015 06:14 PM
Sheared another distributor gear pin AbandonedBronco Ford Inline Six, 200, 250, 4.9L / 300 20 06-05-2014 01:22 PM
Lost My Camshaft Synchronizer. Fordzilla80 Ranger & B-Series 10 12-05-2013 07:25 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
