1990 F250 4x4 351W (was rough idling) now starting problems - Ford Truck Enthusiasts Forums
Old 07-27-2014, 09:06 PM
Kelmaur Kelmaur is offline
Kelmaur is starting off with a positive reputation.
Need some help please
I have a 1990 F250 4x4 with a 351W in it..I just bought a year ago and has had a new engine rebuild probably around 4 or 5 years ago and the lady I bought it from bought another truck and used this one on the farm only.....when I bought it it ran like a bat out of hell..very good....and I have driven it everyday since last August...so a couple of weeks ago I hear a ticking sound..found out it was the coil wire arcing. From the wire to the coil itself replaced the wire and the coil...Problem Solved
Then it was idling rough..and had a loud air sound coming from it...wasn't an exhaust leak..all I could get was 3 mph out of it..no power when try to accelerate....so parked it and although it would crank it would idle rough
Found where the air was coming from...rust hole in the egr valve tube...replaced that..still idling rough and try to give it gas it wants to die....changed the egr valve itself..same thing...rough idle try to give it gas it wants to die.....still sounding like it is not getting enough air..so I changed the idle air controller..
Now it won't start....just turns over and wants to start everyone in a while....took the air hoses off..plenty of suction coming into the throttle body
Seems like it is getting plenty of fuel pressure...I opened the valve on the fuel rail and gas shot out of it there....I don't have a sure way to check fuel pressure
I have not changed the fuel filter....I hear the noise (connection being made) to the fuel pump when I turn the key on.....
This truck has set up for a while before I bought it..so the parts I changed probably needed to be changed anyway
This thing ran damn good for the last year and all of a sudden this....I am not an auto mechanic but I know a little about a little..LOL....and this is throwing me
Any help would be appreciated.....by the way...I am restoring this truck....no old Fords need to be just sitting.......LOL
Thanks in Advance...Kelly
Old 07-28-2014, 10:57 AM
jd460 jd460 is offline
jd460 is starting off with a positive reputation.
Fuel pump possibility
I had a 93 Bronco 351W for many years. I had a similar problem to yours, it would die out when giving it gas, and lacked power. Then it died completely.
After some investigation, I discovered that I had spark, fuel, and air. I too could hear the pump running when I turned the key. On a side note, the float in the gas tank had a hole in it and the fuel gauge wasn't working. Long story short, replaced the fuel pump to fix the gauge and everything cleared up! Although it was getting gas, apparently it didn't have the required fuel pressure.
Good luck
Old 07-28-2014, 11:20 AM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Does sound like a lack of fuel pressure or volume.
Old 07-28-2014, 12:32 PM
Jd460....my fuel gas wasn't working either and I had the exact same problem..float had a hole in it..but got that fixed a month or so ago
Old 07-28-2014, 12:49 PM
Thanks for the help..I'll check on that
Old 08-02-2014, 09:08 PM
Replaced fuel filter and still not starting.so before I get a fuel pump
I'm going to check to see if it is getting fuel and check to see if it is getting spark....
1991 460/7.5L EFI broken down along the road...again **SOLVED** ExPACamper Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 28 09-16-2016 06:26 PM
Rough idle after repairs HELP Tim Harper 1987 - 1996 F150 & Larger F-Series Trucks 26 04-11-2016 06:00 PM
Rough idle Seth95 1999 to 2016 Super Duty 4 12-23-2015 01:49 AM
2001 Sport Trac needs a little...... Buyerfind General Automotive Discussion 7 09-27-2014 07:20 PM
Engine idle problem refueler1 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 07-19-2002 10:06 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
