crager mag - Ford Truck Enthusiasts Forums
crager mag
Old 07-27-2014, 04:30 PM
colson327 colson327 is offline
colson327 is starting off with a positive reputation.
crager mag
I have a 49 f1 with stock wheels/tires. I would like to put on old style original cragar mags. Is there anything I might want to look out for?
Any comments would be welcome.
Old 07-27-2014, 04:37 PM
AXracer's Avatar
AXracer AXracer is online now
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
They are reproducing a number of the older wheels including the Cragers. If buying new make sure you get the proper backspacing you need.
Old 07-27-2014, 04:55 PM
ChuckRob's Avatar
ChuckRob ChuckRob is offline
ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.
if you doing a disk brake conversion on the front you may need to run a spacer between the disk and wheel. This would also require a different depth lug nut.
I have 15x8 on the rear with P275/60 and 15x7 on the front with P245/60 no clearance issues or problems incountered. CRR-29201 spacer kit on the front
Old 07-27-2014, 06:21 PM
Rimrock F1's Avatar
Rimrock F1 Rimrock F1 is offline
Rimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud of
Cragar makes them in the original steel and in aluminum. They have different offsets. I had the steel ones on my 56 Fairlane and switched to the aluminum as the offset difference solved a rubbing issue.
Old 07-27-2014, 07:01 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
I've done the disc brake conversion on my 49 and have run Cragars. I didn't have to run a spacer, there were no clearance issues.
I've heard of other people with the disc brakes having clearance issues and have had to gently remove a little material from the back of the disc brake caliper.
Old 07-28-2014, 05:30 AM
Bluey Zedoff's Avatar
Bluey Zedoff Bluey Zedoff is offline
Bluey Zedoff has a great reputation on FTE.Bluey Zedoff has a great reputation on FTE.Bluey Zedoff has a great reputation on FTE.Bluey Zedoff has a great reputation on FTE.Bluey Zedoff has a great reputation on FTE.Bluey Zedoff has a great reputation on FTE.
Classic wheel on a classic truck. The stylists working at Cragar really knew their stuff. I still think they look as good as anything on the market today.
Old 07-30-2014, 06:19 AM
So if I'm not running disc brakes, no problems? I think your truck looks great with those mags, love it.
Old 07-30-2014, 07:50 AM
nassi nassi is offline
nassi is starting off with a positive reputation.
Quote:
Very well said.
Old 07-30-2014, 10:08 AM
CharlieLed's Avatar
CharlieLed CharlieLed is offline
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
I had them on my 56 til I swapped suspensions, timeless styling for sure...
Added Note: the Cragars on this truck came with the unilug pattern which made it nice since the truck had a mid-fifties GM rearend in it. If you need different lug patterns then Cragars can meet those needs.
Old 07-30-2014, 03:22 PM
3golfjack's Avatar
3golfjack 3golfjack is offline
3golfjack is gaining momentum as a positive member of FTE.3golfjack is gaining momentum as a positive member of FTE.
I've always loved Cragers.I went thru Summit Racing when I purchased my set. They come in what ever backspacing you need.
Old 07-31-2014, 07:16 PM
Rimrock F1's Avatar
Jeg's has a sale going right now on Cragers. Prices look OK and free shipping.
JEGS High Performance
Old 08-01-2014, 10:55 AM
bryanknie's Avatar
bryanknie bryanknie is offline
bryanknie has a good reputation on FTE.bryanknie has a good reputation on FTE.
American Racing is reproducing some old wheels now too. Torq Thrush TTQ, (google them) and in my pic. Mine are 235x60 on 7 inch up front and 275x60 on 8.5 in the rear, all 4 inch backspace with disc brakes up front, no spacers needed and no rubbing. Good pics in my Album.
Old 09-01-2014, 05:46 PM
stevekantercool stevekantercool is offline
stevekantercool is starting off with a positive reputation.
The Cragar SS wheel is probably one of the best looking wheels going. They look great on old vehicles. I have had Cragar SS wheels on many of my hot rods. But, they are the absolute worst piece of crap going, and I won't own another set.
Sometime in the late 70's or 80's Cragar changed their plating process, and literally, if the wheel just sits in the rain, they rust. The new plating process has created a tremendous amount of upkeep.
If you call Cragar, they'll tell you to clean them with steel wool, or have the hoops powder coated. Cragar will do nothing to fix the problem.
If you can find a set of Cragar's from the early 60's or before they changed their plating process, those might be alright.
Think twice. Good luck.
Mag-Hytec Transmission Pan jeremiah77 Excursion - King of SUVs 16 08-10-2015 01:10 PM
Mag style hubcap. center insignias/ bsa_bob2 WTB - Parts & other 3 07-16-2015 08:37 PM
Ordered a Mag-hytec diff cover 86-IDI Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 03-10-2015 02:12 AM
Dilemma Over Adding Mag Hytec Covers... Shogunles 6.7L Power Stroke Diesel 34 03-04-2015 11:47 AM
Mag wheels jonesa49f1 1948 - 1956 F1, F100 & Larger F-Series Trucks 32 06-08-2014 04:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
