Hi David,
The carb does have a governor on it...does that change anything you previously said other than the gasket issue? Also, when you say reset the idle screw to a known point, how do I find this known point?
Hi David,
Thanks,
Noah
The service manual will give you a base line setting. I would start at 1 and 3/4 turn out from lightly seated.
As to the governor, you need to get the right kit, try NAPA
