FICM voltage - Page 3 - Ford Truck Enthusiasts Forums
FICM voltage
  #31
Old 08-18-2014, 03:54 PM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is offline
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
Is the plug and harness at the back of the alternator in good shape? Might want to look at it closely, a good connection here is important. Unfortunately, the rebuilt units from the chain stores don't have a good track record on a 6.0 powered trucks. While they might work ok on a gasoline powered sedan, the load on them is pretty high with the diesel.
After going thru a couple of alternators myself, I took one to a local shop for repairs. After returning it the first time they fixed it by installing some different "heavy duty" parts and it's been working correctly for a couple of years now. Like yours the indication was an intermittent BAT light on the dash.
  #32
Old 08-18-2014, 05:44 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Quote:
Originally Posted by Rusty Axlerod View Post
Is the plug and harness at the back of the alternator in good shape? Might want to look at it closely, a good connection here is important. Unfortunately, the rebuilt units from the chain stores don't have a good track record on a 6.0 powered trucks. While they might work ok on a gasoline powered sedan, the load on them is pretty high with the diesel. After going thru a couple of alternators myself, I took one to a local shop for repairs. After returning it the first time they fixed it by installing some different "heavy duty" parts and it's been working correctly for a couple of years now. Like yours the indication was an intermittent BAT light on the dash.
I agree with Rusty...
The problem with my Autozone alternator was the fact that the regulator needed to be replaced with one that had a higher set point. (14.2 instead of just 13.5)
cranking numbers Fbg 6.0L Power Stroke Diesel 5 03-13-2017 03:20 PM
intermittent no start topkuz 6.0L Power Stroke Diesel 14 02-16-2017 09:36 AM
6.0 no start. Using scangauge please help Trevorafish 6.0L Power Stroke Diesel 19 02-05-2017 12:10 PM
FLP question fireman660r 6.0L Power Stroke Diesel 9 05-03-2016 04:23 PM
Early 2004 F250 6.0 Crank,but no start Fotno 6.0L Power Stroke Diesel 4 08-22-2015 02:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
