Fluid questions - Ford Truck Enthusiasts Forums
Fluid questions
Old 07-27-2014, 02:01 PM
M.Wardwell M.Wardwell is offline
M.Wardwell is starting off with a positive reputation.
Fluid questions
How do I figure out what type of tranny, transfer case, and rear end fluids I need to buy? I purchased the truck used and it didn't have any manuals or any other paperwork which may indicate what I need.
Old 07-27-2014, 05:13 PM
cb_13's Avatar
cb_13 cb_13 is offline
cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.
The trans dipstick should have it written on there, should be Mercon V on an 04-08. The transfer case will take either Mercon(original spec) or Motorcraft Transfer Case Fluid(revised spec). The rear axle will have a tag with spec as well should be 75w140 some labeled as 75w90 were later revised to 75w140. The front diff takes 80W90 but myself and many others used 75w90 as it is a full synthetic.
Old 07-27-2014, 05:16 PM
cb_13's Avatar
You should be able to look up everything on Motorcraft.com as well. I know you could in the past at least.
Old 07-27-2014, 06:43 PM
papasmurf40's Avatar
papasmurf40 papasmurf40 is online now
papasmurf40 is starting off with a positive reputation.
Or on ford.com or under owner and you will get a selection of owners manuals to download for whatever vehicle you need.
Changing power steering fluid 08' mattymax 1999 to 2016 Super Duty 2 10-16-2016 05:15 PM
2003 Rear Differential Fluid Type? daveplot 1997-2006 Expedition & Navigator 11 06-27-2011 01:05 PM
Brake bleeding ? Nice Work Truck 6.0L Power Stroke Diesel 16 10-26-2009 12:44 AM
fluids? wheelhoppin67 1973 - 1979 F-100 & Larger F-Series Trucks 19 04-15-2009 12:01 AM
help-- transmission fluid tag187 1999 - 2003 7.3L Power Stroke Diesel 1 07-19-2008 10:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
