Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-10-2003, 11:34 PM
lennyb44 lennyb44 is offline
Garage is empty, add now
lennyb44 is starting off with a positive reputation.
1988 Ranger won't start
My 1988 Ranger with fuel injected 2.3 and 5 speed won't start.
Was running fine when I took it to work. Would not start when I went to go home 9 hrs later. Cranks over just fine, but won't fire up. Had to tow it home. Didn't have any spark from the coil, so I replaced that. Still no spark. Ran a 12 volt tester light from ground to the red input line on the coil. Lights brightly, so it appears I have power to the new coil. I'm stumped. Can anyone help?
  #2 (permalink)
Old 04-19-2004, 02:42 AM
bkavernix bkavernix is offline
bkavernix is starting off with a positive reputation.
88 ranger won't start
Hi. I'm new to this site but I do have an 88 ranger, and it had a 2.9 in it. I had this same problem all the time, but I would go buy a new fuel pump relay put it on and she would run right as rain until next time.
  #3 (permalink)
Old 03-26-2007, 01:03 PM
bryrykim bryrykim is offline
bryrykim is starting off with a positive reputation.
i just recently bought an 89 ranger 2.3 and i had the same problem i had to change the computer try that it started the first time
  #4 (permalink)
Old 04-12-2007, 01:10 PM
G2IC_Wraith G2IC_Wraith is offline
G2IC_Wraith is starting off with a positive reputation.
I have an 88' 2.3L that didn't want to start at one time. As a matter of fact it died while sitting at a stop light, and would NOT fire. I had to push the POS ~5 blocks down the street to my house. :
After a week of 2 of trouble shooting it turned out to be the plug under the coil where one of the wires had separated from it's connection. It didn't matter that I had good battery, good coil, good plugs, etc.... when the power wasn't even getting to them.
If you haven't done so, make sure you check the inertia switch for proper operation and connection.
__________________
88' Ranger XLT Supercab, 4x2
2.3L, 5sp "dirt brown color"
In loving memory of Dr. Carl R. Swenson - R.I.P. Cigarettes DO kill.
In loving memory of Geordie - R.I.P. You are deeply missed each and every day.
Tags
1988, 23, 88, attempt, cranks, dies, electrical, fire, ford, forums, inertia, lights, ranger, start, switch, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
