2008 6.4 Radiator question
I have had the radiator replaced as well as the upgraded hoses and degas bottle under warranty (after a unrelenting fight with Fomoco). Does anyone have accurate info on whether the upgraded parts (hoses/degas bottle) have improved the reliability of the cooling system? I know the new radiator is the same as the one they took out. Truck only has 47K on it and the replacement work was done at 35K. Totally stock because I have the Ford extended 100K warranty.
While I believe what you say is positive and true, I don't believe that is purely the reason behind failing radiators.
I can't explain everything in detail, because I'm just not that smart.
I had an airlock in my engine for 2 or 3 weeks once, caused coolant puking, rad hoses leaking, and all kinds of problems.
Drained the coolant, added it slowly, like really slowly, and haven't lost a drip in almost 2 years. I can't explain what happened. Glad I didn't run out and spend 4000$ on head gaskets and studs though.
I disagree.
Coolant/ oil mixing
Took my 08 f350 6.4L super duty diesel in to get serviced. It was spitting white smoke out the tail and overheated several times over the past few days. Recently purchased this truck at 69k miles and using it for commercial purposes. I maintain it properly, but do not know of how this vehicle was used or abused before me. Ford told me the oil and coolant are mixing and the oil coolant reservoir cracked or something, and there was a bad hose. Btw my name is Tony, I'm fairly new and would appreciate a little feed back from you experienced ford users'. Thank you fellas. Just wanted to know what could cause these problems? Besides being 6 years old and now being put to work. Since the date of purchase I have accumulated 20k miles. Sitting on 89,000 miles now.
The truck is under warranty so a new reservoir and hoses are covered, but correct fluids will be replaced at my expense. They also ran diagnostics with the code reader and everything came back okay. But usually when I run after about 50 to 75 miles the wrench light comes up. They said it would be a maintenance issue, but where would I begin?
