fuel tank compacity
I would be careful with filling the filler tube. Could get gas or diesel in the vapor charcoal can and ruin it.
To the OP, I don't know if you're asking a question or making an observation.
You shouldn't be letting your fuel get that low anyway. It's a bad bad habit. That's why ford has sort of built in the reserve. Your $50,000+ truck does NOT like air in the system. Filling up at 1/4 is cheap insurance to prevent a multi thousand dollar fuel system repair.
Have to agree with Trey, I don't know why you'd want to run it any lower than that. If you haven't run out of fuel you don't know exactly how much usable fuel that you have left. DON'T run your truck out of fuel to find out, you can cause permanent catastrophic damage to your high pressure fuel system.
No reason to fill all the way up to the filler neck either. Never understood the purpose of that.
Hutch or Harpoon mod, plus 5.5 gallons without having to trickle any in. Used to go 27 gallons when the pump would click, now it goes 32-33 gallons. No extra time, no extra effort, just not wasting the air space in the tank.
I'm not understanding the aversion from you and Tom. It's a proven mod that was originally posted a decade ago next month right here on the SD board, guzzle put it on his page, and I've seen it on other diesel boards. I'm not exactly breaking new ground here.
Welcome to guzzle's In-tank Hutch Mod Web Page
https://www.ford-trucks.com/forums/2...ml#post1762191
I'm not understanding the aversion from you and Tom. It's a proven mod that was originally posted a decade ago next month right here on the SD board, guzzle put it on his page, and I've seen it on other diesel boards. I'm not exactly breaking new ground here. Welcome to guzzle's In-tank Hutch Mod Web Page https://www.ford-trucks.com/forums/2...ml#post1762191
To each his own I guess.
