1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
fuel tank compacity
Old 07-27-2014, 09:54 AM
rakm5898's Avatar
rakm5898
rakm5898 is offline
fuel tank compacity
i have a 2014 350 crew diesel short box. im told i have a 28 gallon tank but cant get over 22 gallons in it even though my gage show e and my read out says i have 10 milesleft until empty? dealer says the left over 6 gallons is a reserve
Old 07-27-2014, 10:49 AM
weyland426's Avatar
weyland426
weyland426 is offline
yeah, sucks doesn't it? i have a 30 gal and have never put more than 27 gal in it even after going into reduced power mode when reading empty.
Old 07-27-2014, 10:51 AM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
Stuff it with more diesel until you see it in the fill neck. Mine used to take +5 gallons after the handle clicked before I did the harpoon mod, now it takes 32 gallons and tops off with maybe an extra 1/2gal.
Old 07-27-2014, 05:37 PM
BigMix's Avatar
BigMix
BigMix is offline
I can never get more than 30 gals in my 35 gal gas tank. I have never liked the idea of not knowing exactly how much fuel I really have left. Is it too much to ask to have an accurate gage?
Old 07-27-2014, 06:01 PM
TosaFords's Avatar
TosaFords
TosaFords is offline
There is about a 5 gallons reserve after the needle hits E and the message center reads 0 Miles Until Empty. I had to run 40 miles after the empty mark once because that was the closest gas station. I put over 36 gallons into the tank. It was starting to sputter when I would stop and go.
Old 07-27-2014, 07:35 PM
DomsF250's Avatar
DomsF250
DomsF250 is offline
I would be careful with filling the filler tube. Could get gas or diesel in the vapor charcoal can and ruin it.
Old 07-27-2014, 07:46 PM
texastech_diesel
Token Redneck
Diesels (at least the HEUIs) don't have an evap canister.
Old 07-28-2014, 04:52 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
To the OP, I don't know if you're asking a question or making an observation.
You shouldn't be letting your fuel get that low anyway. It's a bad bad habit. That's why ford has sort of built in the reserve. Your $50,000+ truck does NOT like air in the system. Filling up at 1/4 is cheap insurance to prevent a multi thousand dollar fuel system repair.
Old 07-28-2014, 05:44 AM
Tom's Avatar
Tom
Tom is online now
Have to agree with Trey, I don't know why you'd want to run it any lower than that. If you haven't run out of fuel you don't know exactly how much usable fuel that you have left. DON'T run your truck out of fuel to find out, you can cause permanent catastrophic damage to your high pressure fuel system.
No reason to fill all the way up to the filler neck either. Never understood the purpose of that.
Old 07-28-2014, 09:04 AM
texastech_diesel
Token Redneck
Why not turn wasted air space into an extra hundred miles on a tank?
Old 07-28-2014, 09:56 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Well I don't know what you're doing, but both times I filled to the neck I got 3 gallons. Which doesn't net me 100 miles. Simply not worth my time.
Old 07-28-2014, 11:04 AM
texastech_diesel
Token Redneck
Hutch or Harpoon mod, plus 5.5 gallons without having to trickle any in. Used to go 27 gallons when the pump would click, now it goes 32-33 gallons. No extra time, no extra effort, just not wasting the air space in the tank.
I'm not understanding the aversion from you and Tom. It's a proven mod that was originally posted a decade ago next month right here on the SD board, guzzle put it on his page, and I've seen it on other diesel boards. I'm not exactly breaking new ground here.
Welcome to guzzle's In-tank Hutch Mod Web Page
https://www.ford-trucks.com/forums/2...ml#post1762191
Old 07-28-2014, 01:17 PM
BPofMD's Avatar
BPofMD
BPofMD is online now
Received 1,097 Likes on 997 Posts
When you happen upon a place that has a good price on diesel you want to get as much in as possible!!!!!!!!!!!!!!!
Old 07-28-2014, 01:21 PM
Tom's Avatar
Tom
Tom is online now
I'm not understanding the aversion from you and Tom. It's a proven mod that was originally posted a decade ago next month right here on the SD board, guzzle put it on his page, and I've seen it on other diesel boards. I'm not exactly breaking new ground here. Welcome to guzzle's In-tank Hutch Mod Web Page https://www.ford-trucks.com/forums/2...ml#post1762191
No aversion, just that I don't see the point in spending the time doing it, than that's all. About the only way I would go through the effort to pull the tank for more fuel capacity would be to install a bigger tank.
To each his own I guess.
Old 07-28-2014, 01:33 PM
rkool's Avatar
rkool
rkool is offline
For me, filling up to the neck is force of habit. Always have. Different pumps click off at different pressures. To get best accurate gas mileage, keep filling up to the top, calculate off of my trip odometer, and reset.
Does it really matter? Probably not. Guess I am a little ****...
Quick Reply: fuel tank compacity
