My truck with 250k+ on original injectors started ticking like a tappet, then started occasional light knocking and now sounds like a rod wanting to come through the block and puffing white smoke like one holes not firing. All fluids are ok, oil looks fine, gauges were all i the normal range. Looking through some past threads it sound like maybe a broken injector tip?? Will that cause any internal damage?
More info: I checked for codes and none were listed. I've done a buzz test and they all buzzed with only slight variations in sound. I hate to start it to do a contribution test for fear of causing damage. Has anyone been down this road before?
Would a leaking cup make it knock like a rod wants to escape? I have all kinds of nasty visions going through my mind like dropped valve or broken rod/piston etc. but I'm hoping for something less distructive.
A bad cup probably wouldn't cause a knock. A bad injector could certainly cause white puffing exhaust and a knock though. You might have to start it and cut off each injector one at a time to isolate the problem cylinder. That's what a shop would do anyhow, honestly. Pull the valve covers and make sure there aren't any obvious issues with the valvetrain first and you'll have access to start popping injector harness connectors off.
I've had several diesels and had injector failures but none have been These newer high pressure oil driven units. I've heard that they knock but holy cow I never thought it would be this loud. If I pull the plug from the problem cylinder would the knock stop?
My bet is that you have a broken or split nozzle on one of your injectors. Your description sounds exactly like when I had a nozzle split around 250k miles. Isolating the bad injector and unplugging it might help....not sure because I've never tried it.
When l watched the first video saw down a ways was a video from a Brandon Girardi that unfortunately sounded more like my problem..a broken skirt. Does anyone know if you remove the oil plug can you see the bottoms of all 8 holes with a borescope? Or is there a splash pan in the way. I've never had one of these apart.
Ahhhh yes... The perfect reason to have dual EGT gauges, it would definitely help narrow down one bank and you'd have something to compare to (the opposite bank).
These guys have you covered, I just wanted to ad some food for thought
