Fuel Pump Connector Wiring Order - Ford Truck Enthusiasts Forums
Old 07-27-2014, 06:05 AM
overhaulin's Avatar
overhaulin overhaulin is offline
overhaulin is starting off with a positive reputation.
Well I took the Ford out a few times since all the recent repairs and she seemed to be working fine until I hit a chuckhole in the road and then she died...time to call out the flatbed.
Any I found a wire that came out of the fuel pump harness connector that houses the wires that connect to the top of the pump on my 90 F-Super Duty. When I reached up to reconnect it I found that the plastic harness connector had disintegrated. Now that I have a new connector I don't know what order the wires go back in. Any ideas?
As always thanks for all your help and advice, its been priceless!!!
Old 07-27-2014, 09:22 AM
F350 1990's Avatar
F350 1990 F350 1990 is offline
F350 1990 is starting off with a positive reputation.
On the F-Super Duty, the midship tank is a two pin connector --- the BK (black) goes to Pin 57 and the DB-Y (dark brown/yellow) goes to Pin 673.
Rear tank is a three pin connector --- the BK goes to Pin 57 and the Y-LB (yellow/light blue) goes to Pin 675. The third pin is unused.
I'll dig out some connector pictures later..........have to run ...............
Old 07-27-2014, 03:48 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
This should be the order of both front and back tanks:
Old 07-27-2014, 09:04 PM
overhaulin's Avatar
Hey SubFord, Thanks as always, but I can't quite make out the colors in your picture, I do have 4 wires,but can you tell me what they are from left to right or send me another photo?
Thanks again!
Old 07-28-2014, 07:49 AM
subford's Avatar
Left to right would depend on direction you are looking at it from.
Top to bottom in the the photo would be:
Front or mid tank:
Orange wire : pump ground
Red wire: pump power
Dark blue wire with yellow stripe : From dash gauge (sender signal)
Black wire: gauge ground (sender ground)
Rear tank or main tank:
Brown wire with white stripe: pump power
Yellow wire with light blue stripe : From dash gauge (sender signal)
Old 07-28-2014, 10:51 AM
overhaulin's Avatar
You are are the Ford Truck guru...awesome...thank you again!!!
Making a stand alone EFI harness (pics) NotEnoughTrucks2014 Engine Swaps 1 Today 11:38 AM
Fuel pump wiring maverick600 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 08-14-2016 07:53 PM
2004 Ford Escape XLT "fuel pump" Melinda Jacobs Escape & Escape Hybrid 1 03-05-2015 02:01 PM
TFI system problems sgauvry 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 07-01-2013 05:48 PM
2004 Ranger Fuel Pump Shut Off Switch Problems ptm Ranger & B-Series 1 05-03-2013 10:17 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
