6.0 Rebuild
6.0 Rebuild
I wanted to start a new thread to show the rebuild of my brothers 6.0. He is not is a hurry since his truck still running fine (just a little blowby). Block is bored .020 over and was decked .005, crank is turned .010/.010. He has an extra set of heads, if he can stay within Ford specs he will use them, if not he will be using them as cores for Ford remans. He purchased a Ford Over haul kit, so everything so far is OEM with the exception of the main and rod bearings, and they are Clevite.
He also has a set VR 20mm HGs that in the kit, we are hoping to get THAT straightened out next week.
I am pretty excited to help because I am getting to see the parts I've only heard about... For instance, I didn't know the bed plate also serves the purpose for the main bearing caps, pretty crazy...
6.0 Rebuild by Shaneb75 Picture 1536701 - Ford-Trucks
6.0 Rebuild by Shaneb75 Picture 1536700 - Ford-Trucks
6.0 Rebuild by Shaneb75 Picture 1536699 - Ford-Trucks
6.0 Rebuild by Shaneb75 Picture 1536698 - Ford-Trucks
6.0 Rebuild by Shaneb75 Picture 1536697 - Ford-Trucks
More to come.....
More to come.....
That is a good question. I am interested to know as well. Between what was removed from the deck, and what will be from the heads have to stay within spec... Seems like it would be tough to do without having new heads.
Hi Shane, I'm in the middle of a rebuild also. Word of advice... if you want to have lazy guys like me look at your pics, get them hosted on a site like photobucket and post them instead of the links.
My block is being decked... I will need to see it and talk to the machinist, but I'm not sure a 0.005 cut would cause any problems. I just measured my old head gaskets, and came up with a 0.059 gasket thickness. Assuming a zero piston deck height(IIRC) you shouldn't need to shave the pistons. All of this is theory, I don't have the block here.
Did the Ford overhaul kit include lifters, and what was the price?
