94 bronco tranny issues - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 07-26-2014, 11:47 PM
wildcard221's Avatar
wildcard221 wildcard221 is offline
wildcard221 is starting off with a positive reputation.
I have had a 94 bronco for a year now with the 351 mounted up to an automatic 4spd with overdrive(can't remember which tranny it is) anyways shortly before winter hit it was having what seemed to be tranny slipping hard shifts and shifts at weird times. I looked it up on a few pages and found out its either the tranny or a solenoid in said tranny that makes it appear the whole tranny is going out...as soon as winter hit I didn't have any more issues at all and it has just started to have issues again since its hot outside again....anyone know what it is or how to tell if it is this solenoid or if its the whole tranny being replaced and could the weather somehow be affecting it?
Old 07-27-2014, 01:53 AM
jasoncarpenter1's Avatar
jasoncarpenter1 jasoncarpenter1 is offline
jasoncarpenter1 is gaining momentum as a positive member of FTE.
Check for codes..............
Probably solenoid, but check for codes first.............
Old 07-27-2014, 11:57 AM
Swit Swit is offline
Swit is starting off with a positive reputation.
Ditto on Jason's, 'check for codes'. Even intermittent issues should leave a CM code. (If you don't have a code reader I'd recommend getting one, although a paper clip can also be used.)
In your 94 the automatic transmission is the E4OD.... and it is heavy on the Electronic.
Presumably your tranny is full on fluid, but *not* overfilled.
A couple of things to read up on:
Search for 'loose filter' and 'MLPS' and/or 'Limp Mode', and fuses:
MLPS (Manual Lever Position Switch) also known as a Neutral Safety switch (auto parts catalogs seem to list under the latter)
Loose filter, some symptoms are similar to yours, notably the intermittent behavior.
Limp Mode- shifting is typically at higher RPM and somewhere between 'What the ___?' and 'OMG I broke it!' hard. Not even slightly subtle.
Fuses #8 and #18 are tied into systems that tie into the transmission and other stuff. (I'm currently hunting one of these down.) You don't mention losing fuses so it probably isn't an issue... burnt fuse doesn't match with intermittent symptoms.
Good hunting....
Nick
Old 07-27-2014, 07:11 PM
so i used my code reader and assuming i used it right i got codes for EGR valve postion and EGO sensor .....im going to double check later this evening and see what i get....it didnt show any codes with the engine running just key on engine off.....which im not sure if its normal or not....
Old 08-03-2014, 06:48 PM
jowens1126 jowens1126 is offline
jowens1126 is starting off with a positive reputation.
Could be as simple as a MLPS sensor. Sounds like you aren't keeping it cool enough too. Do you have an aux cooler?
Please begging someone helppppppp nick_ct_203 1997-2006 Expedition & Navigator 24 01-14-2016 03:22 PM
99 expy tranny help needed asap nick_ct_203 1997-2006 Expedition & Navigator 0 12-31-2015 04:45 PM
46RE: Is My Buddy's Tranny Guy Trying to Rip Him Off? opr8r Clutch, Transmission, Differential, Axle & Transfer Case 2 10-05-2014 10:15 AM
94 bronco, transmission, converter issue igotoneforya 1978 - 1996 Big Bronco 18 09-02-2011 12:28 PM
1996 F-350 7.3L PSD transmission Issues / DTC P0500 mudtug2 1994.5 - 1997 7.3L Power Stroke Diesel 4 07-06-2011 03:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
