Home Brewed 70 Short Bed Build
#1022
Thanks Gary
I ordered the cover from Quiet Ride. I thinking I will do about the same thing out of alumium on the Mustang. Here is a link the Quiet Rides covers.
PDF.js viewer
#1023
on
I also got mine from Quiet Ride but did not want the FORD logo as that's where my light gets mounted. I did mine with out removing the hood. After, I figured out how to install while it was still on the truck.
My way of doing it.I had to grind or sharpen points on the dowel hold the vinyl in place to get the screws started.
#1025
on
Russ this is what the under side looks like, it comes with 1/2" pre cut insulation pads.
But, I was first going to use some stuff called KEEP COOL it's a 1/4" foam type sheet by Prorod glued that first then glued the Q.R over the Keep Cool padding an tapped sides over.
I ended up doing 3 layers total of insulation. I copied Q rides padding an taped it over Q rides then 3rd was covering the whole thing. And lastly the 3/32th black vinyl cover.
#1026
on
I'm guessing that with your efforts, & triple coverage, you've made your ride a symphony of mellow tunes. I've done the Dynamat, and filled in the void spaces between the X framing already. I know that with the Dynamat in my doors, and the little I've done under the hood, I've knocked down the "Drum" effect by over half. Like in most things, "Diminishing Returns" increase with added layers. ie, The first layer does the most, less with the 2nd. and less again with the 3rd. Kind of wish I had a decibel meter, other than my old ears. Just for science you know, so I can feel justified when my wallet cries. "Now, now there wallet, it will only hurt for a little while"... After all, don't you want to be quiet like a Mercedes when you grow up?
Baja
Baja
#1027
Baja
Baja
#1029
Everything you did is bound to help. Orich can tell you better then I can what covering the hood does. I did mine before I had driven it, so I know what it is now, but couldn't tell you how much difference just doing that would make.
#1030
on
This already made some difference, and that last piece is on now. I can tell you it makes the hood heavier.. or I need more oil on my hinges.. then again, its no doubt that at 71, I am not the Hulk any more.. I'd like to think that its weak springs, not weal arms, but I'd be kidding myself.
Baja
Baja
#1031
on
Baja
Baja
No need to go to the GYM just drive old manual steering & lift the hood a few times a week keeps me in shape.
Orich
