Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
  #1 (permalink)
Old 07-26-2014, 08:16 PM
PRUSue PRUSue is offline
PRUSue is starting off with a positive reputation.
Help preventing siezed brake line couplers
I'm tired of every time I do brake work on my truck, the line fittings or bleeder valves are frozen (usually from the PO overtightening but not always). I'm currently starting to replace all the old lines with new stainless ones.
As a result I've started putting a tiny dab of caliper grease on the threads of brake fittings. Is this the worst idea anyone has ever had and it will lead to untold sorrow, or is this a legitimate way to prevent the problem.
Thanks for the input.
  #2 (permalink)
Old 07-26-2014, 08:54 PM
skyway0018746 skyway0018746 is offline
skyway0018746 is starting off with a positive reputation.
Use never seize .... dont use stainless fittings! Stainless while being good at preventing corrosion easily gauls and might as well be rusted solid.
  #3 (permalink)
Old 07-26-2014, 10:02 PM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Workaholic
77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of
"Never seize" or "anti seize" compound on the threads of the bleeder valve will work wonders (remove it completely and coat all the threads) and that rubber cap on over the end will keep road grim from building up.
Specialty Lubricants - Anti-Seize : Permatex® Nickel Anti-Seize Lubricant
Or after you get them broke loose the first and get the brake bleed done. Just dab some grease on the whole thing. It works great like putting a dab of grease on the battery cable ends to keep the corrosion from building up.
__________________
77&79 F250 Rich & Penny
77 351M auto, factory a/c add a leaf 33x12.50's
78 (79 headlights) 460 4 spd, factory a/c and 35's
79 351M 4spd 6" Skyjacker Edelbrock-Holley-Hedman 35's
99 Ranger 4x4, 98 Expedition 4x4, 73 Bronco Hillbilly-Bug
71 Bronco 302 35" Boggers 5.58 gears spool/locker
  #4 (permalink)
Old 07-26-2014, 10:03 PM
77&79F250's Avatar
Workaholic
Oops fat fingered it.
__________________
  #5 (permalink)
Old 07-27-2014, 12:53 AM
dittohead dittohead is offline
dittohead is starting off with a positive reputation.
Every bolt i pull off anything i work on either gets never seize or loctite. It saves ridiculous amounts of time and effort later on if you live anywhere that sees salt. On brake line what i do is pull back the fitting and put neverseize on the tube under the nut as well as on the threads.
  #6 (permalink)
Old 07-27-2014, 07:32 AM
Blue and White Blue and White is offline
Blue and White is starting off with a positive reputation.
Agree the grease or antisieze helps. A comment on stainless... it is hard to seal and hard to repair. Lubing the fittings and tighten-loosen-tighten helps the sealing. Any flaring requires a really high end tool ($200-$500?) so repair or modification is very difficult. Personally I stick with mild steel.
  #7 (permalink)
Old 07-27-2014, 08:51 AM
dustyroad's Avatar
dustyroad dustyroad is offline
dustyroad is gaining momentum as a positive member of FTE.
One of the best purchases you can make is a big bottle of anti-seize.
__________________
I really do attempt to google first, sometimes my googlefu is weak though.
1979 F150 4x4 460/np435
1988 E250 "falcon" class B 351/c6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
