2002 excursion a/c nightmare of 7 years - Ford Truck Enthusiasts Forums
Old 07-26-2014, 07:59 PM
2002exPSD's Avatar
2002exPSD 2002exPSD is offline
2002exPSD has a good reputation on FTE.2002exPSD has a good reputation on FTE.2002exPSD has a good reputation on FTE.
So I bought my excursion 7 years ago. Since then the a/c has sucked. Been to 3 ford dealerships, multiple repair shops and my a/c instructors in automotive college have all looked at the truck including myself. The a/c has always been cool in the summer, freezing cold at night, freezing cold on the interstate, freezing cold in the winter. Pressures are as follows. Ambient 95 deg humidity 62%. At idle 51 psi low 217 psi high compressor does not cycle. 1500 rpms low 45 psi high 265 psi compressor does not cycle.
A little info on my system. Last winter the compressor and clutch, evaporator(front ac), accumulator, fot(yea it's the right color), and condenser were all replaced with oem ford parts bought straight from my local dealer. Also all the low side a/c lines were wrapped in foam. Ambient was in the 40's at the time. Couldn't get the right amount in the truck. Summer comes and top it off properly. Still the same problem. I've had excuses from multiple shops tell me it's cool air because the truck is black. Obviously false statement. My father has the identical truck (black) but gas 2wd and 2 years newer. His ac is ice cold all the time. He has to turn it down cause it's too cold.
What else could me and all the shops be missing for 7 years? I'm almost to the point of selling my baby cause I can't deal with the crappy ac another summer.
Old 07-27-2014, 07:52 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Does that vehicle heating/cooling system use the same blend door arrangement as so many other Ford's do? Between that part and the dash mounted temp control I'd look there.
I did the same sort of swap minus evaporator on my 2000 E250, get about 40* leaving air temps at the vents, 65 MPH 90*+ days.
Old 07-27-2014, 07:57 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Does your Exc have the valve in the coolant lines to shut off coolant through the heater core in MAX A/C? Does it work?
What is the actual outlet air temp (center vent, high speed, temperature stabilized, 1500 RPMs) as measured with a thermometer?
Old 07-27-2014, 10:25 AM
2002exPSD's Avatar
Eatc doesn't display any code so I assumed that end was all good.
Old 07-27-2014, 10:29 AM
2002exPSD's Avatar
Has coolant valve not sure if it works. Will get back to you on that one.
Still looking for my digital thermometer. Going by another one today.
98 Ranger a/c compressor not cycling 1998Ranger25L153CID Ranger & B-Series 4 01-03-2016 09:48 AM
1999 F150 AC compressor cycle time mizzleman Cooling, Heating, Ventilation & A/C 3 07-13-2015 05:07 PM
03 Expedition a/c not cooling daveplot Expedition & Navigator 3 05-31-2013 10:58 AM
1992 Ford Explorer air conditioning JRF Explorer, Sport Trac, Mountaineer & Aviator 1 09-22-2012 08:46 PM
A/c works when truck is cold then stops after truck is warm mechman787 1997 - 2003 F150 8 07-19-2008 07:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
