'67 F600 Tune Up Specs - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 07-26-2014, 07:40 PM
dbreienrk1 dbreienrk1 is offline
dbreienrk1 is starting off with a positive reputation.
I recently purchased a '67 F600 with a 330 2V Medium Duty FT engine and a 4-speed manual transmission. It's a pretty stock under the hood and it's a weekend vehicle so no high-performance parts or setup is needed.
Does anyone know the specs for a complete tune-up? I read the air/fuel ratio should be 13:1 vs the standard 14.7:1...any thoughts on this? Also, what spark plugs would you recommended I install? Ideally, I'd like to know...
Spark Plug Gap
Point Gap
Cam Angle
Ignition Timing BTDC
Firing Order
Idle Speed RPM
Fuel Pump Pressure
Compression Pressure
Old 07-26-2014, 09:55 PM
gangstakr's Avatar
gangstakr gangstakr is offline
gangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud ofgangstakr has much to be proud of
Do you have the 67 hood emblems for the F600?
Old 07-26-2014, 10:02 PM
Quote:
Are you referring to the chrome "FORD 600" emblems on the left and right fenders? Yes, but not really relevant to what I was asking...
Old 07-27-2014, 12:41 AM
orich's Avatar
orich orich is offline
orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.
Plugs gap .030
points .017
dwell 26-31
Timing 10 BTDC
Idle speed 525 rpm stand tranny, auto 500
Compression 140 psi
Plug type BTF-31
Hope this helps!
Orich
Old 07-27-2014, 12:46 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
[quote=dbreienrk1;14535930]............ I read the air/fuel ratio should be 13:1 vs the standard 14.7:1...any thoughts on this? .....................
They like 'em to run rich to help keep them cooler. Lean it out and combustion temps start to go up. Lean it out and run it WOT all day (as you may have to with a 330) and you might hole a piston.
Gas was cheap, improved pistons and other combustion chamber changes etc were expensive.
Did you get a 2 speed axle?
Old 07-27-2014, 11:03 AM
Quote:
Yes, but I'm not using it to haul so it won't really be used.
Thanks for the info on the air/fuel ratio.
Quote:
Originally Posted by orich View Post
Plugs gap .030
points .017
dwell 26-31
Timing 10 BTDC
Compression 140 psi
Plug type BTF-31
Hope this helps!
Orich
Thank you! Much appreciated.
Old 07-27-2014, 04:48 PM
My dad would shift 2-3-4 in low and used the high rear axle setting as another gear when empty. Easier on the clutch maybe.
239 Ignition Timing F-100CustomCabTBC Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 9 07-02-2013 11:22 AM
Some specs for a 262 engine carprojects 1961 - 1966 F-100 & Larger F-Series Trucks 2 06-13-2010 02:37 AM
tune up specs smbikes 1973 - 1979 F-100 & Larger F-Series Trucks 3 09-06-2009 10:36 PM
Spark plug gap anyone??? Fordbyford 1978 - 1996 Big Bronco 23 03-29-2005 09:09 PM
Tune-up spec 360/390 bh2112 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 11-08-2004 11:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
