1949 F-1 Temp Guage
Old 07-26-2014, 06:22 PM
rhildebrand's Avatar
rhildebrand
rhildebrand is offline
1949 F-1 Temp Guage
New to this Site but need some help: Wiring up stock gauges - still on 6 volt system on a 1949 F-1 with 239 v8, All Gauges work well Except Temp Gauge. Both Thermal Switch and Sending Unit are new, Wiring to Units are new, Truck is Running 160 Degrees After Warming Up, When you Turn Key on and Crank Engine - Gauge goes from Hot to Cold - Good. As Engine Warms up Temp Needle will come to Say 1/4 or Half (Normal) - OK - Then when you idle the truck up - The Temp Needle will Start Back to "C" - Let Engine set at Idle and Needle will Move Back Toward Normal? Any Ideas on Why the Gauge would do this while Idling Up ??
Old 07-26-2014, 07:47 PM
ben73058's Avatar
ben73058
ben73058 is offline
Hey Rhildebrand,
Welcome to the forum. Good to see another Texas guy on here with a '48-'50. I've got no answers on your question - electric experts will chime in soon hopefully.
I would warn you that the temp sender on these trucks looks like a wire but it is in fact a hollow line full of a Mercury like substance. We made the mistake of yanking it off to work on an overheating problem. I don't think you want that stuff on your skin.
Good luck over there.
Ben in Austin
1950 F1
Old 07-26-2014, 08:18 PM
Skalywag's Avatar
Skalywag
Skalywag is offline
My guess is that your thermostat is opening and closing causing the temperature readings to fluctuate, and running at fast idle you are moving more air through the radiator causing the engine to cool down. My two cents, it sounds like it is operating ok.
Old 07-26-2014, 08:30 PM
rhildebrand
But the more you keep it at fast idle - It will go all the way to "C" and stay there until you idle down and it will slowly creep back up ?
Old 07-26-2014, 08:45 PM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
The new switch and sending unit are for 6V application, right?
Old 07-26-2014, 08:49 PM
rhildebrand
Yes - Ordered from Carpenter
Old 07-26-2014, 08:53 PM
rhildebrand
Maybe Bad Switch/Sending Unit - Did a lot of Wiring Today - Looking from back of Gauge - Wire from Ignition on Left Pole - Wire out to Sending Units on Right
Old 07-26-2014, 11:30 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
The oil pressure, temp, and gas gauge all have steel straps distributing power between them, from a wire connected to the Accessory or GA terminal on the ignition switch.
I'd guess you have a thermostat that is stuck open partway, or is real slow to respond. Are the belts reasonably tight? As much as thermostats cost, I'd replace both just so you know they're fresh. I recommend these, they are all the same but branded differently:
Stant 14157
NAPA THM 111
Murray 4157
O'Reilly 2962
https://www.ford-trucks.com/forums/1...l#post14361585
Old 07-27-2014, 06:02 AM
colson327's Avatar
colson327
colson327 is offline
Be glad she's running cool. I've done everything I could think of on my 49 f1 239 flathead and she still runs too hot. Looking for s radiator shroud but seems impossible to find one ANYWHERE!
Old 07-27-2014, 08:57 AM
rhildebrand
Well Maybe I need to Change the Thermostats - I Know the Engine is Running Cool - Still Don't Add Up for the Gauge to Act Normal Until you Give it Gas and it will go all the Way over on the Downside of "C" and stay there until you let it Idle?
Old 07-27-2014, 09:34 AM
FortyNiner's Avatar
FortyNiner
You have a real head scratcher. The correlation of the gauge and engine speed would seem more of a wiring issue than thermostat performance. I would recheck all the connections. Keep us posted, please.
DW
Old 07-27-2014, 09:52 AM
rhildebrand
That's what I'm Thinking - Wiring Issue Somewhere - Will be Checking Again Maybe Today
ALBUQ F-1's Avatar
ALBUQ F-1
What temps are you seeing when cruising at a steady 40 - 45 mph in summer weather? With two independent cooling systems joined at the radiator, and the gauge only on one side, there may not be good mixing of one cold side and one normal side at idle, but enough to change the reading when you rev it up.
Old 07-27-2014, 01:47 PM
hooler1's Avatar
hooler1
hooler1 is offline
To rule out a problem with the gauge and sender, I would try temporily swapping over to a mechanical style gauge. That way you can eliminate or isolate it to an electrical issue. Or better yet using an infrared temp gun. Opinions very about where to shoot the temp sample from. I would do it near where the temp sensor is now. Once you rev your engine see if the temperature goes down. You can check both sides and compare. I agree with those who may believe its a thermostat issue. Could be one side is stuck open. Also you mention you installed a sensor and a switch. You didn't accidentally mix them up and put the switch into where the temp sender was supposed to go? Just a dumb suggestion. Its something I would probably do.
Old 07-27-2014, 04:13 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
7RC-10883 .. Instrument Cluster Temperature Gauge / Obsolete
1948/50 F1/F8 & F5/F6 COE
NOS PARTS LTD in Waxahachie TX has ONE = 972-937-2201.
NOS PARTS SOURCE in Olathe KS has ONE = 913-220-5746.
Quick Reply: 1949 F-1 Temp Guage
