best place to chain up for shock loads - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-26-2014, 06:38 PM
rs4-380 rs4-380 is offline
rs4-380 is starting off with a positive reputation.
ie. stump pulling.
Where the best place (in terms of not damaging the truck) to attach a chain to, around a hitch ball?, the receiver cross tube?, the front hooks?
Old 07-26-2014, 07:40 PM
351Cleveland C4's Avatar
351Cleveland C4 351Cleveland C4 is online now
351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.
Hitch ball on a good strong mount.
Old 07-26-2014, 07:46 PM
nojoke327's Avatar
nojoke327 nojoke327 is offline
nojoke327 has a good reputation on FTE.nojoke327 has a good reputation on FTE.nojoke327 has a good reputation on FTE.
Not the front tow hooks or yours will look like mine. The rear hitch is your best bet
Old 07-26-2014, 07:50 PM
Dang, how'd you do that???
Old 07-26-2014, 07:59 PM
99150's Avatar
99150 99150 is online now
99150 has a spectacular reputation.99150 has a spectacular reputation.99150 has a spectacular reputation.99150 has a spectacular reputation.99150 has a spectacular reputation.99150 has a spectacular reputation.99150 has a spectacular reputation.99150 has a spectacular reputation.99150 has a spectacular reputation.99150 has a spectacular reputation.99150 has a spectacular reputation.
Quote:
Originally Posted by rs4-380 View Post
ie. stump pulling.
Just FYI.......I was doing this one time, when the chain broke. The broken chain link went through my rear diff cover like a bullet!!!!!!! I have often thought about..."What if it had come through the rear window!!!!!!
YIKES!!!!!!!!!!!!!!!!! But it is your truck and your time!
Best of luck to you and yours!
Old 07-26-2014, 08:02 PM
Yea don't be dumb about it. Chains are very dangerous if not used properly. Don't give it all slack then take off like a mad man. Short, solid jerks are best for stump removal.
Old 07-26-2014, 08:10 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Always lay a blanket or old coat on the chain or strap, ideally about 1/2 between you and what you are pulling.
If the chain or strap breaks it will just lay down.
Old 07-26-2014, 08:29 PM
do you guys recommend going around the receiver cross tube or using a ball mount/pintle type hook?
Old 07-26-2014, 08:33 PM
senix's Avatar
If you have a pintle then that would be ok, otherwise I would go around the receiver on both sides of the ball/pintle to spread the load out.
Old 07-26-2014, 09:16 PM
An empty ball mount with a 3/4" screw pin clevis works well too.
I would go around the ball. It is made to handle the load and spread it to the receiver. Applying force anywhere else is going against the engineering design.
Old 07-26-2014, 09:17 PM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is online now
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
I wouldn't wrap the chain around my hitch. As soon as you go to yank the chain will bind into the receiver and scratch bend and dent the crap out of it. If you really must use a heavy duty pintal hitch and do short almost no slack jerks, better yet buy a 40k tow strap thats what I have when I pull smaller trees and scrubs out. I use a 1/2" six foot long chain around the tree/shrub then a 20T shackle thats hooked between the chain and strap loop and the other loop of the strap directly to the receiver pin. I also use a old heavy dickies jacket layed on the strap just incase something breaks
galaxy S4 using IB AutoGroup
Old 07-26-2014, 09:18 PM
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
Buyers Receiver Mounted Tow Eye, 12,000 GTW - Tractor Supply Co.
Plus 40k# strap with sewn eyes, that way the only connection that's not fabric wrapped through a sewn eye is the forged eye in the receiver
Old 07-26-2014, 09:30 PM
Hang on just a second here, were recommending this guy go out and get big heavy duty stuff, and for all we know the stump is only a sapling.
To the OP, what kind of stump, how big, what kind of ground, what prep work has been done, and what equipment do you already have?
Old 07-26-2014, 09:48 PM
Disgruntled Texan
I recommended a rubber band that only shoots hunks of metal away from my truck, I think that's pretty much what I'll call a "universal application".
Putting a strap around a 2" chrome ball is like an adult Red Ryder bb gun when the shank shears off.
Old 07-26-2014, 10:00 PM
99150's Avatar
Backhoe works best!!!!!!! If it is a big enough to worry about breakage!!!!
Tire chains Trophy_23 1999 to 2016 Super Duty 10 12-13-2016 08:08 AM
where to attach to pull engine? 49f3dls 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 07-02-2016 10:06 PM
Timing chains super tight paintslinga2010 Modular V8 (4.6L, 5.4L) 1 03-20-2016 09:41 PM
What's the best way to hoist a 460 and C6? Highboy74 1973 - 1979 F-100 & Larger F-Series Trucks 13 04-12-2015 01:15 AM
Tire Chains LesWard 1999 - 2003 7.3L Power Stroke Diesel 1 07-08-2014 12:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
