Help removing door glass
Clips have been removed already and the regulator mechanism is raised and out of the way. The problem is the glass will not drop into the bottom of the door. The channel guides keep the door from lowering.
With the window still attached to the clips, try cranking the regulator until the cotter pins are at the top of the access opening, then remove the cotter pins and have a friend lift and hold the glass up in the door channel from the outside, then crank the regulator up all the way. Reach in and lower the glass to the bottom of the door. I think that's how it went for mine. The trick is raising and/or lowering the regulator linkages to get it out of the way after the glass channel is detached from the regulator arms.
On my driver's side, the guide closest to the door jamb had a thin sheet metal tab that could have easily kept my glass from falling down into the door if I hadn't noticed it and bent it out of the way. Curiously, the passenger side (and neither side had been touched....probably ever) didn't have it. Check and see if there is a tab at the bottom of those guides that's keeping it from sliding down and out.
You can see from this pic that the glass has dropped below the bottom of the guides and is being held up at the spot where it's hitting the inside of the door.
This is the drivers side I am working on. I don't find any clip holding the window in the guide. The window is hitting the door and that seems to be what's keeping it from dropping to the bottom. This pic shows where the glass is hitting the door. I'm wondering if my guides are bent or something.
You may need to pull down the first little part of the window seal on top to give the division bar enough room the slide over. It has small screws holding it in place. It will flex quite a bit, but be careful not to damage it or permanently bend it.
I ordered all of my new felts, anti-rattle kits, division bars, seals and glass from LMC Truck. They are one of the few suppliers who still stock the glass. The shipping was reasonable, and they pack it unbelievably well. They wrap it in big bubble shrink wrap, then they put it in a box and spray foam all around it inside the box. You can go to their website and shop until your wallet empties itself.
Did you get the glass out of the door?
I spent just over $600 total on all new glass, seals, felts, channels, division bars, and anti-rattle kits in two separate purchases from LMC earlier this summer. It makes a world of difference, but, make no mistake, it's a big job that takes some time. You'll "love" the legendary clips that hold the anti-rattle felts in place. If you're gonna replace glass, you might as well put new felts and seals in it. That's like Cinderella wearing flip-flops to the ball.
For comparison, those same two windows are $79.90 on sale at LMC right now. So, when you factor in shipping, it's about the same. And you can rest assured the glass will fit. When you factor in the time, gasoline, having to take the old glass with you for a pattern (and quite often it will be broken), and the other unknowns, it's much easier to order it in my opinion. I forgot to mention, I tried to get my windshield cut locally. The guy charged me $150, and it didn't fit well at all.
