"Open Loop" Fuel System - Ford Truck Enthusiasts Forums
Old 07-26-2014, 01:45 PM
fyreduck1921's Avatar
fyreduck1921 fyreduck1921 is offline
fyreduck1921 is starting off with a positive reputation.
Good afternoon,
I have a 2006 F-150 4x4 with the 3-valve flex fuel 5.4L engine. In November 2013 the truck started cutting out. No Check Engine light ever came on, but using a OTC #3109 OBDII Scan Tool, I discovered that the fuel pressure was bottoming out to below 10psi. Based on the advice of this forum, I replaced the Fuel Pressure Driver Module. My problem was gone until recently.
When operating at low rpm (around 1200) on the highway, and the load increases, such as climbing a hill, the truck will again stumble. Again, I have no engine light. Plugging in the scan tool shows NO drop in fuel pressure. However, the Fuel System Loop Status changes from CLOSED to OPEN.
Everything else is within normal parameters as far as I can tell. What could be causing this, and how do I fix it?
Thanks,
Steve
2003 5.4 expadtion no fuel pressure milehieagle 1997-2006 Expedition & Navigator 22 10-09-2016 11:35 AM
91 F150 shuts off while driving/lope idle boggerted 1987 - 1996 F150 & Larger F-Series Trucks 7 10-25-2015 06:01 PM
Misfire with no CEL Iceman2415 1997 - 2003 F150 8 06-14-2015 05:11 PM
F250 open loop mode reason? looking 1987 - 1996 F150 & Larger F-Series Trucks 5 11-21-2007 07:44 AM
open or closed loop seumas Ranger & B-Series 8 06-13-2004 08:40 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
