f350 diesel water problem
I have 2004 F350 6.0 diesel, 30k miles that has a water problem that I can not cure. Water light comes on, engine loses power, can die, light goes off, will restart or continue to run. Have drained fuel from the water drain under the frame rail several times, replaced filters, tried additives that state they remove water. I also have run the tank almost empty. Has been going on for several tanks of fuel. Happens when cold, or hot, often or not.
Also don't use any of the additives that say that they
remove water. All it does is emulsify the water
and get all the way to the injectors. That is not something
you want happening. 6.0 Injectors and water don't get along.
Like others have said. Time to clean the water separator
chamber on the pump. Stop and pick up a new gasket and
a few cans of spray carburetor cleaner to get the gunk cleaned out.
BTW what brand of filter are you using? The Motorcraft or the Raycor
filters have a water barrier and most of the aftermarket stuff does not
along with a few other shortcomings.
The last thing I would do once you have the pump cleaned is do a
pressure test. Just to make sure that you getting enough pressure.
Do you have the upgraded fuel pressure regulator spring aka : Blue spring?
Sean
EDIT : One last thought. Come on over to here and read the tech folder at the top for more info on the 6.0L
https://www.ford-trucks.com/forums/forum107/
Sean
This is a nice little upgrade:
HFCM OEM Water Separator Drain Upgrade Plug - Riffraff Diesel Performance
Go finger tight on it putting it in because it seals with an o-ring, but if it starts getting stubborn in the winter you can get it with channel locks. If you have a 4x4 the plug acts like a wick and no more diesel on the driveshaft, but I still use a cut down 1 liter water bottle to catch what comes out. Clear is easy to see small amounts of water and debris at the bottom.
For the fuel and oil filters:
S3624, Socket, Filter Flip, 24 and 36mm, 3/8" square drive
