95 f250 locker - Page 2 - Ford Truck Enthusiasts Forums
95 f250 locker
Old 07-31-2014, 04:24 PM
zackcj7's Avatar
zackcj7 zackcj7 is offline
zackcj7 is gaining momentum as a positive member of FTE.zackcj7 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by 408 Torquer View Post
Well, that doesn't sound to good to me. Sideways is not good. I also thought about changing the fluid like others suggested. Maybe will try that first, but also thought about going to 4.10 ratio or somewhere around there. Going to put 35" General Grabbers on it and want to do everything at same time to save labor. If I do locker work at the same time as I change the ratio, am I avoiding any rework and labor that way?
Yes, it would be best to have the locker installed at the same time as the new ring and pinion.
I have had or currently have almost all of the locker types mentioned in this thread. If you can afford it, go ARB. The mini compressor ARB sells is very easy to install and not too pricey. The ARB doesn't affect street driving at all when it's not on, but when you have it on it locks solid. Plus it helps to be able to turn it off on the trail when you need to make sharp turns.
Old 07-31-2014, 05:28 PM
Nothing Special's Avatar
Nothing Special Nothing Special is offline
Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.
Any locker or limited slip will reduce stability. If a tire isn't spinning it is a lot harder to make it slide sideways than it is to roll forward. So with an open diff when you spin one tire the other is just sitting there, helping you not slide sideways.
Once you put in a locker or limited slip you introduce the possibility / probability that you will spin both tires. A spinning tire is already sliding. It doesn't care which way it slides, so it's very happy to slide sideways.
All automatic lockers, including the Detroit, Yukon, Lock-Right and whatever others I'm not thinking of right away, do this worse than limited slips or selectable lockers. Because they will hit that second tire relatively abruptly when they lock.
How bad is it? It depends. I had a Jeep CJ5 with a Detroit that was pretty bad. The short wheelbase made it pretty twitchy to begin with. And manual transmissions also tend to be a little harsher as you get on and off the gas. On the other hand I also had an F-150 SuperCab short box with a Lock-Right that wasn't bad to drive in the winter at all. The long wheelbase didn't tend to swap ends as quick when the tires were spinning, and the auto trans softened the hits too. The F-150 could still be made to fishtail a lot easier than it did with an open diff, but it wasn't bad to drive.
Old 08-04-2014, 11:26 AM
408 Torquer 408 Torquer is offline
408 Torquer is starting off with a positive reputation.
Much appreciated
So many of you seem to know so much about this. I'm amazed at all the good info. Now I think I know enough to make my decisions. Going to be a while to round up all the stuff, but I'm now on my way. Some of you seem like you must be specialized mechanics.
Thanks again.
95 f150 cluster in a 95 f250 Walwal44 1987 - 1996 F150 & Larger F-Series Trucks 12 10-20-2014 04:32 PM
Aftermarket Ls or locker in 2011 up Superduty? superrangerman2002 1999 to 2016 Super Duty 10 10-10-2014 02:53 PM
front locker or L/S units F-250 WARHORSE 1973 - 1979 F-100 & Larger F-Series Trucks 8 08-13-2012 12:01 PM
What axle is in 2WD 99 F250SD? Locker rec? Kerr250SD 1999 to 2016 Super Duty 6 09-15-2008 09:18 PM
locker or LS in front diffie chrowen 1973 - 1979 F-100 & Larger F-Series Trucks 32 10-29-2004 05:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
