Project rebody - Ford Truck Enthusiasts Forums
Project rebody
Old 07-26-2014, 10:34 AM
Robbieo11's Avatar
Robbieo11 Robbieo11 is offline
Robbieo11 is starting off with a positive reputation.
Project rebody
well i have always loved this body of the 69 crew. i lalso have alot of love for the powerstroke. Allot of work has been done to the chassis on the 95 as a bonus it is a 4x4 and od trans 3.55 gears new brakes hardware rebuild rearend.... alot of $$ in it. the body is trash so i got a line on the crew it is 300 miles away so the tape measure. is a long distance affair.
i need a tow rig for my 35 ft camper in the sig line the chassis donor is there also.
can anywone help enlighten me on the issues i know wheel base is differnet by 6 inches the 95 is longer. so whacking, weldig and plating the frame will have to be done or maybe sliding rearend. also cutting the shafts. anyone know the bodymount differences.
also wiring but that will not be that bad
i want a/c i will creating the firewall to get clearance on the downpipe and a/c box. are cabs diffeent widths??
any help would be great
Old 07-26-2014, 03:45 PM
Gicknordon's Avatar
Gicknordon Gicknordon is offline
Gicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to all
Most times these body swaps are harder than they look. These are discussed a lot in the 48 to 56 forum. They usually end up on craigslist half done. Not that it can't be done, but its harder than you think. You need fabrication experience to get it done.
Old 07-27-2014, 07:50 AM
Robbieo11's Avatar
Quote:
Gotta do it talked to my wife. We do not want a truck payment. It will sit alot. Just like my 03 did and like my 95 does. I bought the 95 cheap 3000. And the crew 3500. I want a tow rig for my camper, i want an old classic body. This is where the 69 come in Would love donations lol. 4 inch downpipe and exhaust would be cool tune of the pcm for towing ect. Lol
Looks like the cab has to go forward cutting firewall. Gotta figure out a/c. Anyone have an old a/c heater box out of 67-72 ford truck
Old 07-27-2014, 09:18 AM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
got any pics of the 69? i love those old crew cab trucks. would love to do something similar myself someday - though i don't have one just sitting around like you do.
Good luck and post lots of pics here if you do go through with it!
Old 07-27-2014, 11:42 AM
Robbieo11's Avatar
Will when i get the key
300 miles away gotta go and load it up
Will be 2weeks
Old 07-27-2014, 03:27 PM
Robbieo11's Avatar
Just doing research.
Ext cab wb is 8 inches longer.
Overall length 240" oppose to crew of 116
Rear Cab to front bumper length 133 ext cab to 139 crew
Back of cab to rear wheel c.l. 58 ext to 40 on crew
Calculated. End of cab to c. line of front wheel needs to be 108 for crew 1/2 box gap and 40" for front of short box
So cab has to go forward 6 inches. Cut firewall and reform for psd
Laid out on my frame needs a 9 inch section removed or move rearend 9inches and hack off the end. Hmmm
Old 07-28-2014, 12:11 AM
fordman67's Avatar
fordman67 fordman67 is offline
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
Shorten the frame. Qshortening the drive shaft will be cheap. Moving the rear I think won't work out well.
Old 07-28-2014, 12:24 AM
Robbieo11's Avatar
Quote:
Was thinking the same thing. Also thinking use part of 95 firewall. Seeing issues with pedals and ext lining up
Took a screen shot of firewall on a 79 vid. Looks easier to weld the 95 in
Old 07-28-2014, 08:40 PM
Robbieo11's Avatar
Could add 9 inches to bed
Old 07-29-2014, 08:25 PM
Robbieo11's Avatar
Ran into some snags. You guys
Old 07-30-2014, 10:34 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
I'm not much help on the body swap, but I know these old OBS trucks pretty well and I happen to know where there might be a late 60s early 70s pickup in a yard so I'm subscribing to follow the progress and offer any help I can.
Old 07-30-2014, 06:22 PM
Robbieo11's Avatar
My brother was gonna lend me part of the cash. He backed out looking for funding. Anyone wanna help would pay back tax time.
Everyone say i should or cant do it. I am pissed and want to prove them wrong
Old 07-30-2014, 11:13 PM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Not to be an azz but if you don't have the funds to buy it then how will you build it ?
Old 07-30-2014, 11:17 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
Doesn't matter how well you plan. There's always hidden costs from things you didn't realize or forgot about altogether
Old 07-31-2014, 07:20 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Sounds like a cool project but a lot of work.
9" rear end bjmayberry2 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 08-16-2016 01:04 PM
70's crew cab on 99+ chassis JD_3020 1973 - 1979 F-100 & Larger F-Series Trucks 1 10-18-2014 07:18 AM
69 crew on a 95 ext powerstroke chassis Robbieo11 1967 - 1972 F-100 & Larger F-Series Trucks 3 07-27-2014 03:29 PM
Rebody project 69 cc. To 95 ext cab Robbieo11 1987 - 1996 F150 & Larger F-Series Trucks 1 07-27-2014 03:29 PM
95 powerstroke chassis 69 crew cab swap Robbieo11 1994.5 - 1997 7.3L Power Stroke Diesel 1 07-26-2014 12:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
