Smaller brake booster/other ideas
Hey guys,
After my recent rag joint issue, it got me thinking about how much I would like to get rid of my body lift. The lower steering shaft and steering gear are not in line, there is a slight angle. After a lot of reading, it seems like it SHOULD be okay, but honestly losing my steering from that rag joint failure was enough for me to want to ditch the body lift so I can get rid of that angle.
But, the reason the body lift is there in the first place is so the brake booster clears the valve cover on my engine. Does anyone know of a smaller diameter brake booster that would swap in easily?
I'm also looking for other ideas about ways I can get rid of the body lift. I don't think it's in the cards for me to hydroboost it right now unfortunately. Thanks!
on
I have a '77 F-150 and 400. With the TALL ford Racing valve covers the stock 11" booster wouldn't work. I did some asking around as you are, and I was told use the F-359 DUAL diafram booster it is 9" in diameter. Although I had my stock booster chromed I will use one from Tuff Stuff. I don't know if this will help you at all. Good luck with the truck and glad to hear all was OK with you and your Dad.
What booster do you have now? It's obviously not stock, if it doesn't fit without a body lift.
If the answer is anything besides "Hydroboost from a...." then you should think about hydroboost.
There are plenty of write-ups. And...throughout the entire Internet, as far as I can tell, only one detractor.
Bar none, making the brakes safe with hydroboost on my 79 is the best thing I've ever done for it.
It's been better than the axle shafts, the body damage, the diesel swaps, the onboard air, the lockers, the lift, the bushings, the shackle flip, the re-wire, the tires, the sound system, the insulation, the sound deadener, the headlamp relays, the 3G alternator, the Weiand intake manifold, the Edelbrock 1406 etc, etc, etc.
Perception is reality though.
Pretty sure the f350 (1978) booster is what I used. I don't have the talk 460 valve covers so it really wasn't a problem but I was buy a new booster anyways so went with the upgrade. It depends greatly on which pedal setup you have. If everything you have is 79....it should bolt right in. Oh ya, brake line connections are on the other side of the MC. You'll probably have to run new lines to your proportional valve.
Anyone else have any thoughts on this? I'm thinking this is the route I'd like to go, if it truly is a straight across swap so I can ditch my body lift.
When you're talking about a direct swap, are you talking about JUST the master cylinder?
I've put the F-350 booster and master cylinder on my 79 Bronco. The booster and master cylinder combo should fit on there just fine, but if youre talking about just the master cylinder (or just the booster) I think it's a toss up if it'll work. I know the booster fit onto my stock fire wall and my stock 79 pedal. The master cylinder DID have to have the lines smoohsed over to the other side.
Yeah that's what it would seem like, thanks.
ranger140892
62
05-30-2019 12:30 PM
SMH1970
02-01-2018 05:48 PM
