driveline NOT binding in 4WD?
Old 07-26-2014, 10:11 AM
guessrow's Avatar
guessrow
guessrow is offline
Hello,
I've had occasional issues the last year getting my 04 into 4WD, but at 270K on the original IWE actuators, that's probably to be expected.
I had new actuators ready to install, but took the truck out for a drive before doing the job. On a gravel road the back tires spun easily in 2WD, I switched over to 4wd and it was much harder to spin the tires- you could tell it was in 4WD- or at least seemed that way. I left it in 4WD and tried turning on a tar road and it didn't seem like it was binding at all. (I have an open diff in the rear, assume the front is the same?)
Anyway, I installed new actuators last night and took it out for another drive afterwords. I put it in 4WD and could IMMEDIATELY feel the binding when turning.
What I cant figure out is why I could NOT feel binding while in 4WD prior to the install. Could I have been in 3WD somehow? (04 Super Crew, Automatic, 4.6L, XLT- pretty basic pickup...)
good luck -jim
Old 07-26-2014, 12:06 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
One of the fronts could have been stuck in the released position putting you in 3wd.
Old 07-26-2014, 10:19 PM
1saxman's Avatar
1saxman
1saxman is offline
Well, 2WD actually without limited slip - one wheel can drive at a time on each axle, but it can be either wheel on each axle, so that means any of the four wheels can drive, hence the term '4WD'. There are two causes of 'binding'. One is the CV joints in the front axles on tight turns, and the other is tension induced in the transfer case from making turns on pavement, as one axle completes slightly more rotations than the other, while they are locked together. On a loose/slippery surface the tension is relieved by wheel slip.
Tom_Co
1997-2006 Expedition & Navigator
13
03-12-2019 12:11 AM
mblaksley
02-10-2010 07:45 PM
kittyhawksurf
1999 to 2016 Super Duty
28
07-09-2009 05:44 AM
scratchedvinyl
11-18-2006 03:55 PM
john bagley
13
09-18-2003 10:58 AM
Quick Reply: driveline NOT binding in 4WD?
