driveline NOT binding in 4WD? - Ford Truck Enthusiasts Forums
Old 07-26-2014, 11:11 AM
guessrow guessrow is offline
guessrow is starting off with a positive reputation.
Hello,
I've had occasional issues the last year getting my 04 into 4WD, but at 270K on the original IWE actuators, that's probably to be expected.
I had new actuators ready to install, but took the truck out for a drive before doing the job. On a gravel road the back tires spun easily in 2WD, I switched over to 4wd and it was much harder to spin the tires- you could tell it was in 4WD- or at least seemed that way. I left it in 4WD and tried turning on a tar road and it didn't seem like it was binding at all. (I have an open diff in the rear, assume the front is the same?)
Anyway, I installed new actuators last night and took it out for another drive afterwords. I put it in 4WD and could IMMEDIATELY feel the binding when turning.
What I cant figure out is why I could NOT feel binding while in 4WD prior to the install. Could I have been in 3WD somehow? (04 Super Crew, Automatic, 4.6L, XLT- pretty basic pickup...)
good luck -jim
Old 07-26-2014, 01:06 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
One of the fronts could have been stuck in the released position putting you in 3wd.
Old 07-26-2014, 11:19 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
Well, 2WD actually without limited slip - one wheel can drive at a time on each axle, but it can be either wheel on each axle, so that means any of the four wheels can drive, hence the term '4WD'. There are two causes of 'binding'. One is the CV joints in the front axles on tight turns, and the other is tension induced in the transfer case from making turns on pavement, as one axle completes slightly more rotations than the other, while they are locked together. On a loose/slippery surface the tension is relieved by wheel slip.
Comprehensive question(s) about the A4WD Re: binding TExpedition45 1997-2006 Expedition & Navigator 18 06-10-2015 09:47 PM
4x4 operation questions Jimmy Dean 1999 to 2016 Super Duty 43 02-02-2014 10:25 AM
F250 4x4 operational questions Jimmy Dean Offroad & 4x4 5 01-28-2014 08:41 PM
IWE Actuators countryboy73703 2004 - 2008 F150 4 08-16-2012 05:59 AM
Front axle binds bad while turning in 4wd 91Bronc300 1973 - 1979 F-100 & Larger F-Series Trucks 5 09-29-2011 10:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
