Fluid questions
Old 07-27-2014, 01:01 PM
M.Wardwell's Avatar
M.Wardwell
M.Wardwell is offline
Fluid questions
How do I figure out what type of tranny, transfer case, and rear end fluids I need to buy? I purchased the truck used and it didn't have any manuals or any other paperwork which may indicate what I need.
Old 07-27-2014, 04:13 PM
cb_13's Avatar
cb_13
cb_13 is online now
The trans dipstick should have it written on there, should be Mercon V on an 04-08. The transfer case will take either Mercon(original spec) or Motorcraft Transfer Case Fluid(revised spec). The rear axle will have a tag with spec as well should be 75w140 some labeled as 75w90 were later revised to 75w140. The front diff takes 80W90 but myself and many others used 75w90 as it is a full synthetic.
Old 07-27-2014, 04:16 PM
cb_13's Avatar
cb_13
cb_13 is online now
You should be able to look up everything on Motorcraft.com as well. I know you could in the past at least.
Old 07-27-2014, 05:43 PM
papasmurf40's Avatar
papasmurf40
papasmurf40 is offline
Or on ford.com or under owner and you will get a selection of owners manuals to download for whatever vehicle you need.
Mark_in_co
03-09-2017 01:52 AM
parcours
1999 to 2016 Super Duty
23
12-22-2016 10:03 AM
sdeforest
1997 - 2003 F150
03-16-2007 09:53 AM
ddoyle777
2004 - 2008 F150
02-05-2005 09:17 PM
built2rev
1997-2006 Expedition & Navigator
07-13-2004 03:22 PM
Quick Reply: Fluid questions
