95 powerstroke chassis 69 crew cab swap - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-26-2014, 08:49 AM
Robbieo11's Avatar
Robbieo11 Robbieo11 is offline
Robbieo11 is starting off with a positive reputation.
posted both places need info
well i have always loved this body. i love the powerstroke. alot of work has been done to the chassis on the 95 as a bonus it is a 4x4 and od trans 3.55 gears new brakes hardware rebuild rearend.... alot of $$ in it. the body is trash so i got a line on the crew it is 300 miles away so the tape measure. is a long distance affair.
i need a tow rig for my 35 ft camper in the sig line the chassis donor is there also.
can anywone help enlighten me on the issues i know wheel base is differnet by 6 inches the 95 is longer. so whacking, weldig and plating the frame will have to be done or maybe sliding rearend. also cutting the shafts. anyone know the bodymount differences.
also wiring but that will not be that bad
i want a/c i will creating the firewall to get clearance on the downpipe and a/c box. are cabs diffeent widths??
any help would be great
Old 07-26-2014, 01:54 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
I hope you are a REAL good fabricator.
I have seen this done with a 95 reg cab/69 reg cab
And also on a 03 crew cab / 96 crew cab.
BOTH were huge projects
70's crew cab on 99+ chassis JD_3020 1973 - 1979 F-100 & Larger F-Series Trucks 1 10-18-2014 08:18 AM
Project rebody Robbieo11 1994.5 - 1997 7.3L Power Stroke Diesel 21 08-31-2014 12:45 PM
69 crew on a 95 ext powerstroke chassis Robbieo11 1967 - 1972 F-100 & Larger F-Series Trucks 3 07-27-2014 04:29 PM
Rebody project 69 cc. To 95 ext cab Robbieo11 1987 - 1996 F150 & Larger F-Series Trucks 1 07-27-2014 04:29 PM
which body for 88 7.3 idi obsguy Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 02-06-2014 07:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
