69 crew on a 95 ext powerstroke chassis - Ford Truck Enthusiasts Forums
Old 07-26-2014, 08:47 AM
Robbieo11's Avatar
Robbieo11 Robbieo11 is offline
Robbieo11 is starting off with a positive reputation.
well i have always loved this body. i love the powerstroke. alot of work has been done to the chassis on the 95 as a bonus it is a 4x4 and od trans 3.55 gears new brakes hardware rebuild rearend.... alot of $$ in it. the body is trash so i got a line on the crew it is 300 miles away so the tape measure. is a long distance affair.
i need a tow rig for my 35 ft camper in the sig line the chassis donor is there also.
can anywone help enlighten me on the issues i know wheel base is differnet by 6 inches the 95 is longer. so whacking, weldig and plating the frame will have to be done or maybe sliding rearend. also cutting the shafts. anyone know the bodymount differences.
also wiring but that will not be that bad
i want a/c i will creating the firewall to get clearance on the downpipe and a/c box. are cabs diffeent widths??
any help would be great
Old 07-27-2014, 12:31 AM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
First find out in new york if it is legal to re-frame a vehicle.
Garbz
Old 07-27-2014, 03:23 AM
Robbieo11's Avatar
Ya its ok a few years ago i was a fleet managerfor a cable company we had a kid try and move a pole the new truck ended up needing a frame swap
Old 07-27-2014, 04:29 PM
Robbieo11's Avatar
Just doing research.
Ext cab wb is 8 inches longer.
Overall length 240" oppose to crew of 116
Rear Cab to front bumper length 133 ext cab to 139 crew
Back of cab to rear wheel c.l. 58 ext to 40 on crew
Calculated. End of cab to c. line of front wheel needs to be 108 for crew 1/2 box gap and 40" for front of short box
So cab has to go forward 6 inches. Cut firewall and reform for psd
Laid out on my frame needs a 9 inch section removed or move rearend 9inches and hack off the end. Hmmm
70's crew cab on 99+ chassis JD_3020 1973 - 1979 F-100 & Larger F-Series Trucks 1 10-18-2014 08:18 AM
Project rebody Robbieo11 1994.5 - 1997 7.3L Power Stroke Diesel 21 08-31-2014 12:45 PM
400 in a 95 mustang? 400inatruck 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 11 08-14-2014 01:27 AM
Rebody project 69 cc. To 95 ext cab Robbieo11 1987 - 1996 F150 & Larger F-Series Trucks 1 07-27-2014 04:29 PM
95 powerstroke chassis 69 crew cab swap Robbieo11 1994.5 - 1997 7.3L Power Stroke Diesel 1 07-26-2014 01:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
