2000 F250 Ticking/Knocking Noise - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-26-2014, 08:21 AM
F350Man79 F350Man79 is offline
F350Man79 is starting off with a positive reputation.
I have a 2000 F250 5.4 that has a ticking/knocking noise. After about 30-60 seconds of first starting the truck in the morning, the ticking/knocking noise appears. It sounds like its coming through the exhaust system and seems to be louder under the front passenger side wheel well. When I rev the engine up, it seems to go away. Does this engine have a cam phaser? Could it be timing chain slap? Any input would be appreciated. Thanks!
Old 07-27-2014, 12:00 PM
J88wagner's Avatar
J88wagner J88wagner is offline
J88wagner is starting off with a positive reputation.
I too have the same sound in my 01 CCSB 5.4. Goes away after awhile. I do know that our yrs don't have cam phasers. My mechanic said that one of the rods has become mis-shaped and after the oil pressure builds up the noise goes away. Told me I have 10,000-50,000 miles before the motor is toast. Anyone else have this issue?
Old 07-27-2014, 10:33 PM
AAubinoe AAubinoe is offline
AAubinoe is starting off with a positive reputation.
Maybe a bad exhaust manifold? Mine ticked like crazy at startup (2004 2v 5.4L). I replaced my muffler that had a hole and it became apparent that I had a leak.
I could see a broken stud and feel the leak.
Old 07-27-2014, 11:12 PM
J88wagner's Avatar
It's not a ticking it's a knocking sound.
Old 07-28-2014, 09:40 AM
speakerfritz's Avatar
speakerfritz speakerfritz is offline
speakerfritz is gaining momentum as a positive member of FTE.speakerfritz is gaining momentum as a positive member of FTE.
how many miles do you folks have....
had an 05 with 88K tha made the ticking noise that I thought was phaser, lifters, etc...but turned out to be cracked exhuast manifold.
have an 08 with 57K and it makes no noises at all.
Old 07-28-2014, 10:15 AM
Kdr358's Avatar
Kdr358 Kdr358 is offline
Kdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to behold
Quote:
Find a new mechanic. I'm willing to bet it's a common exhaust leak, the studs break off and once the engine warms up the sound lessens.
Piston slap is common in these engines at a higher mileage if the cooling system wasn't maintained. That's how my V10 was retired, two burned pistons and the truck was overheated at one point causing the damage.
Old 07-28-2014, 10:16 AM
J88wagner's Avatar
I've got 219,000 miles but like I've said not a ticking noise definitely a knocking/clacking noise.
Old 07-28-2014, 10:25 AM
beachcamperf250 beachcamperf250 is offline
beachcamperf250 is starting off with a positive reputation.
I just did get this truck a few months ago, the odo says 190K on it but I think it was rolled back a few years ago so it probably has 250K+ on it according to past title searches.
Mine does the same for about 10 minutes when I first start it up, it will just stop then come back then stop like something is adjusting in the engine, it will eventually go away once it is warmed up. I have thought about going with a thicker oil to see if that helps.
Old 07-28-2014, 10:33 AM
What do you mean rolled back? Is it not digital?
Since I'm nearing the 200k mile mark quickly, I recently switched to running 5quarts 5w20 conventional and 1 quart hyper lube. Seems to be doing pretty good, could just be all in my head though HA!
Old 07-28-2014, 11:52 AM
Kdr358's Avatar
I have an old vid of my truck when it had the piston slap, I will post it once I get home.
Old 07-28-2014, 03:27 PM
2000's don't have digital odo.
Old 07-28-2014, 08:59 PM
Ahh learn something new everyday. There are quite a few small differences between 1999-2004.
One thing I meant to add about the oil is that from what I have read thicker may not be better. I ran Rotella 15w40 in my AMC 360 in my wagoneer to bring oil pressure up (before I rebuilt the pump), but these over head cam V8s are a different animal. So I'd stick to stock viscosity and maybe an additive if you like.
5.0 ticking/knocking mrford99 5.0L Coyote 6 Today 09:51 AM
Ford 302 Ticking - Lifter Problem? bsraborn 1973 - 1979 F-100 & Larger F-Series Trucks 11 07-12-2016 09:27 PM
ford 390 engine problems!!!!!!!!!!!!!!! zackinno70 1967 - 1972 F-100 & Larger F-Series Trucks 3 03-29-2016 05:28 AM
04 Epedition 5.4L sounds like Power Stroke diesel 120mm Jedi 1997-2006 Expedition & Navigator 10 11-12-2014 12:55 PM
1989 Ford Econoline E250 Coachmen Class B RV engine ticking/knocking noise ASSYRIAN_ELVIS_E250 1968-2013 Full Size Vans 21 10-15-2014 04:40 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
