auto experts c4/6-aod questions - Ford Truck Enthusiasts Forums
Old 07-26-2014, 05:28 AM
Wodahs Wodahs is offline
Wodahs is starting off with a positive reputation.
my question is directed to the auto experts in the house
my understanding is the AOD is basically a retooled C-4 is this correct or just a rough statement
if it is a retooled c4 , if it can be done , how much modification or what needs machining needs to be done to fit aod guts to a c6 main body housing
the reason is I have to modify some part of aod at some stage as its to go behind a 400 and that has a big block bell housing bolt pattern and I have the c6 to suit already , but to modify the aod to suit means cutting off the bell and buying a jw conversion bell
but the main bodys of the aod are as I stated above are meant to be a retooled c4 and look very simular to the c6 in the body
Old 07-26-2014, 09:18 AM
stuart1 stuart1 is offline
stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.
Nope.
Not even close.
About the only similarity is Ford.
An AOD can be made to fit as you said by removing the bell housing.
AOD uses a planetary and a few clutches similar to an FMX.
Pan bolts will interchange.
81 van standard to auto macs40 Clutch, Transmission, Differential, Axle & Transfer Case 1 03-23-2016 12:00 AM
When did the last 7.3 roll off in ky?? Imfubar 1999 - 2003 7.3L Power Stroke Diesel 5 12-16-2014 08:41 PM
Who is the AOD know it all to call? 351Cleveland C4 Clutch, Transmission, Differential, Axle & Transfer Case 24 08-26-2014 06:38 PM
94 e350 box truck AOD trans swap Gearheadman3 1968-2013 Full Size Vans 4 05-30-2014 04:31 PM
56 F-100 FMX to AOD transmission swap hooler1 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 08-13-2013 01:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
