Clunking Brakes???? - Page 2 - Ford Truck Enthusiasts Forums
Clunking Brakes????
Old 08-12-2003, 01:16 PM
truckfreak69 truckfreak69 is offline
truckfreak69 is starting off with a positive reputation.
Clunking Brakes????
Mine does it at take off, I figured it's either ball joints or radius arm bushings.
Old 08-12-2003, 03:38 PM
brannma brannma is offline
brannma is starting off with a positive reputation.
Clunking Brakes????
Solution found- took it back to Bucky's and made them put new broke pads on the fronts again. So far its been 2 weeks and no clunk.
Old 08-12-2003, 05:10 PM
mirrormaker mirrormaker is offline
mirrormaker is starting off with a positive reputation.
Clunking Brakes????
I did have a clunk in my front brakes after purchasing my truck for a guy. It seems that someone put the brake pads in without the anti-rattle clip. I bought a kit when I did my brakes and in contained the clips and new pins. My brakes are quiet now and I much happier. It was actually embarrassing it would be so loud at times.
Old 08-12-2003, 05:21 PM
Bubba Shrimp's Avatar
Bubba Shrimp Bubba Shrimp is offline
Bubba Shrimp is starting off with a positive reputation.
Clunking Brakes????
Man I hate to be at the mercy of those garages. Those pins only cost $4.00 for two pins at Discount Auto. They should have put new ones in to start with when they did the brakes.
I got to raise my rates for fixing computers.
Old 08-16-2003, 10:36 AM
ArmaLube ArmaLube is offline
ArmaLube is starting off with a positive reputation.
Clunking Brakes????
The front brakes on my 1989 F250 HD used to rattle and clunk, expecially in the Winter. Also, braking had a pulsing that suggested a warped disk rotor.
The problem turned out to be worn out brake caliper PINS. New pins cured the problem. The pins and grooves need to be properly lubricated to allow free self adjusting action.
Old 08-21-2003, 06:28 PM
RandysF150 RandysF150 is offline
RandysF150 is starting off with a positive reputation.
Clunking Brakes????
Hey mjb1962, my outer pads rattle bad. What do you mean by "crush" the tabs? Thanks
Help me diagnose this noise coming from my front left wheel. Drenalin 1999 - 2003 7.3L Power Stroke Diesel 17 08-23-2015 09:03 PM
Need Brake Hlelp/Advice RobRoss Excursion - King of SUVs 13 05-29-2015 09:13 AM
Having a STICKY time with my Brakes!! Restlesswildman 6.0L Power Stroke Diesel 15 06-18-2014 08:19 PM
Smoking rear brake - caliper frozen dogerbrown1 1999 to 2016 Super Duty 1 10-24-2011 12:31 AM
Front Brakes Getting Super Hot stevieb Explorer, Sport Trac, Mountaineer & Aviator 6 01-18-2004 06:58 PM
Tags
2000, anti, brake, brakes, braking, clips, clunk, clunking, disc, explorer, f150, ford, front, ranger, rattle, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
