Stuck Distributor in a 351w - Ford Truck Enthusiasts Forums
Old 07-25-2014, 10:03 PM
Shadow944795's Avatar
Shadow944795 Shadow944795 is offline
Shadow944795 is starting off with a positive reputation.
Angry Stuck Distributor in a 351w
Got a fun one, bought a 351w for 600 bucks and tore it down partway, now the guy I bought it off of said it was stuck but I didn't think he meant so ****ing stuck that not even a 3 foot long pipe wrench could turn it stuck, I've broke off the cap trying to get it off and nothing me and dad have done thus far such as beating it with a hammer at various points to try and shock it free or various wrenches and letting it sit with lube in it for a week has done any good. I'm gonna hit it hard sometime tomorrow to try and get it out but I want some extra ideas so I'm not totally flying blind on it. Any and all help and advice as welcome. Thanks in advance, Shadow.
Last edited by Shadow944795; 07-25-2014 at 10:04 PM. Reason: To tired to spell "got" correctly aparently XD.
Old 07-25-2014, 10:06 PM
Tedster9's Avatar
Tedster9 Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
I'd be inclined to (carefully!) try some heat from a torch, along with the required banging and foul language, that usually seems to work in such cases.
Sent from my iPhone using IB AutoGroup
Old 07-25-2014, 10:09 PM
Would a small propane torch be okay? or should I just drag out the oxy/acetylene torch and do that number with it?
Old 07-26-2014, 05:09 AM
xlt4wd90's Avatar
xlt4wd90 xlt4wd90 is online now
xlt4wd90 is gaining momentum as a positive member of FTE.
A small propane torch should do it, if it's going to do it. You want to heat it up, not melt it.
Can you look in from below to see if the base of the body is rusted to the block, or something like that?
Maybe you've done this already, but when I faced a similar situation, I got on top of the engine so I could pull straight up. The distributor popped right out, where as hours of prying and pulling before while standing beside the engine did nothing.
Old 07-26-2014, 05:23 PM
Tedster9's Avatar
Any luck or busted knuckles?
Old 07-27-2014, 05:58 PM
Got busy and had an unexpected guest come in and take up most of my time Saturday and have been working all day today, when I get the chance to touch it I will inform you of how it goes. Wish me luck.
Old 07-27-2014, 09:02 PM
Island Time's Avatar
Island Time Island Time is offline
Island Time has a great reputation on FTE.Island Time has a great reputation on FTE.Island Time has a great reputation on FTE.Island Time has a great reputation on FTE.Island Time has a great reputation on FTE.
I'm waiting to hear your results as I'm in the same situation. I've been letting it soak with Aerokroil. I hate the idea of a torch. I'm always afraid of setting something alight.
Old 07-27-2014, 10:23 PM
Tedster9's Avatar
Never had this happen - (yet) what's the deal anyway, is it heavy corrosion? From dissimilar metals or something, pitting, swelling? On my 292 it popped right out. Assuming when they are stuck like that, no adjustment of timing is possible either?
Old 07-28-2014, 11:50 PM
FordFETruck's Avatar
FordFETruck FordFETruck is online now
FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.
Never had that happen to me. Take the oil pan off, take the oil pump out and then run a long skinny rod up where the drive rod goes and give the end of the rod a hard wack with a big hammer.
The Blue Goose's build thread. Shadow944795 1987 - 1996 F150 & Larger F-Series Trucks 91 11-23-2016 06:26 AM
New guy Ranger1972 New Member Introductions 1 12-16-2015 12:20 PM
Hot cranking issues. Shadow944795 1987 - 1996 F150 & Larger F-Series Trucks 11 09-10-2015 04:46 PM
How tought is the M5OD in the ford trucks? Shadow944795 1987 - 1996 F150 & Larger F-Series Trucks 16 07-06-2014 09:47 PM
351w efi intake suggestion? Shadow944795 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 10 06-28-2014 04:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
