recomended sub $200 OBD2 reader - Ford Truck Enthusiasts Forums
Old 07-25-2014, 09:23 PM
ralbach ralbach is offline
ralbach is starting off with a positive reputation.
I couldn't find a thread via search on this subject so my apologies if I missed it.
Basically looking to purchase an OBD 2 reader but not so badly that I'm willing to spend more than $200. While I own all the shop manuals for my vehicles (2002 Odyssey / 2009 Accord / 2002 F-150) I make no assumptions that I'll recognize the codes so guides or equivalents easily accessible on the net would be worth while.
Thanks,
-robert
Old 07-26-2014, 06:09 AM
CPaulsen's Avatar
CPaulsen CPaulsen is offline
CPaulsen is gaining momentum as a positive member of FTE.
Look at Scan Gauge II
Old 07-26-2014, 08:31 AM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud oftex25025 has much to be proud of
Quote:
What is it that you are wanting the reader to do? Depending on that, you may not be able to get one that is going to do what you want and cost less then $200
Since you have in your profile an 1986 vehicle, that actually is an OBD-I type and those I wouldn't even bother with a reader for. Unless you had an 89 on up Ford as those had more options then the earlier ones (live stream of data etc, but that was just on some).
Now, since you said OBDII, I would imagine that it's for a different vehicle then the one listed in your profile. Depending on what that is, I go back to my first question.
Best obd tool/reader ZekeD 1999 to 2016 Super Duty 10 06-18-2015 06:29 PM
Code reader recommendation bashby 1987 - 1996 F150 & Larger F-Series Trucks 6 11-21-2014 08:25 PM
#10 misfire? BigBlkEX Excursion - King of SUVs 8 06-18-2014 12:33 PM
Obd1 Or Obd2 ? johnanderson 1987 - 1996 F150 & Larger F-Series Trucks 12 05-09-2013 01:58 AM
Looking for Scanner Rusty_S General Automotive Discussion 2 06-24-2012 11:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
