Clutch Pedal Problems - Ford Truck Enthusiasts Forums
Old 07-25-2014, 08:43 PM
1984F2506.9's Avatar
1984F2506.9 1984F2506.9 is offline
1984F2506.9 is starting off with a positive reputation.
I think my clutch is going out, when i push the clutch, shift, and let off the clutch pedal comes a little then stops and then either pops on its own or i pull it with my foot. Is it my clutches or something simpler?
Old 07-25-2014, 10:14 PM
Found the problem its my slave cylinder, anyone know how to remove it?
Old 07-25-2014, 10:23 PM
wtroger wtroger is online now
wtroger is gaining momentum as a positive member of FTE.wtroger is gaining momentum as a positive member of FTE.
If you have a lot of miles make sure the bushings in the clutch shaft aren't wore out and that the stub shaft that the master rod attaches to isn't worn badly. My master is good but the rod eye and stub shaft are worn and cause me to have lift the pedal with my toe.
Old 07-25-2014, 11:56 PM
I dont think its that when i push the clutch all the way down put the truck in gear i can drive around without letting off the clutch
Old 07-26-2014, 12:40 AM
speedwrench72's Avatar
speedwrench72 speedwrench72 is offline
speedwrench72 is starting off with a positive reputation.
proper clutch adjustment is most important, hydraulic clutch's are not self adjusting, to much free play at lever can make the clutch drag
Old 07-26-2014, 04:57 AM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.
Make sure your firewall isn't tearing as well.
clutch pedal spring AJHEATING 1973 - 1979 F-100 & Larger F-Series Trucks 10 07-31-2016 12:32 PM
Clutch Spring Removal- F350 Diesel wantahertzdonut 1987 - 1996 F150 & Larger F-Series Trucks 5 10-27-2015 12:31 PM
Clutch sticking, not engaging txdadof4 1987 - 1996 F150 & Larger F-Series Trucks 2 08-01-2015 02:23 PM
clutch pedal elimination zombiefied 247 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 06-02-2015 11:45 PM
clutch pedal removal emeraldcoupe 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-23-2015 04:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
