86 f250 c6 transmission not shifting.
86 f250 6.9 transmission not shifting. I did a fluid/filter and modulator change. The truck had 1st but no 2nd or reverse. It drove fine for about a mile(still no 2nd or reverse) than started slipping I checked the fluid and it was at the fill line I filled it up again now I have no gears. At 2500 Rpms it shudders Bad and starts to move. The modulator was replaced with a black stripe. Could my torque converter be going out. Or valve body.?
Any help would be great.
Not sure. Might try a tranny shop. Unless you had the tranny out I doubt the TC is misaligned. But if it was out recently and didn't get aligned with the pump and center shaft the the pump would have gotten broke when the tranny was installed. Seen that one before.
here you go http://www.ebay.com/itm/Ford-C6-Transmission-Modulator-Pin-/261526995561?pt=Motors_Car_Truck_Parts_Accessories&hash=item3ce4394269&vxp=mtr
Average length is 1.625 diameter is some where around a an 1/8. if you make one the ends are rounded and i would use some sort of drill rod.
Dusrusg
02-25-2011 04:40 PM
nwebbe1079
04-02-2010 10:35 PM
Brooksd1991
13
09-27-2009 12:20 PM
