Timing Question
Timing Question
Bought a Ford F-150 4.9 Liter 6 cylinder new in 1993 and now has 350,000 miles. Replaced the original distributor & ignition module today because of hard starting. Now the engine starts instantly and seems to be running smooth. Placed witness marks on old distributor before removing placing new distributor as close to witness marks as possible.
Bought a timing light this afternoon having never used one before. Any suggestion about what the degree should be when idling? Where is the timing mark?
Thank you
Thank you
10 degrees BTDC. If the engine is running smooth the timing must be very close.
You need to disconnect the spout connector plug to set the timing.
Here are two threads that should answer your questions.
https://www.ford-trucks.com/forums/1...l#post10469335
https://www.ford-trucks.com/forums/1...-91-4-9-a.html
If the ignition control module (TFI module) is bolted to the side of the distributor follow the wire harness and it looks like the first picture. If you have the remote ignition control module it's towards the back of the driver side fender as shown in the link below.
It's just a plug that makes or breaks the wire connection. You disconnect the plug so the computer does not control the timing.
Click on this link for a picture of the remote TFI module. It's shown in thread #4.
https://www.ford-trucks.com/forums/1...l#post10476486
briguy
17
01-23-2007 06:05 AM
