45k miles, stick w dino oil or switch to Mobil 1 - Ford Truck Enthusiasts Forums
Old 07-25-2014, 07:40 PM
choate's Avatar
choate choate is offline
choate has a good reputation on FTE.choate has a good reputation on FTE.
I'm considering using some Mobil 1 at my next (first for me) oil change just b/c I've always used it in all my cars but what are the thoughts on a 21 year old truck? Just stick to regular oil? Truck doesn't leak anything....For now anyway
Old 07-25-2014, 07:45 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Keep withy the dino oil unless you want to start chasing oil leaks and have more expensive oil changes
Old 07-25-2014, 10:47 PM
cjben cjben is offline
cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.cjben has a spectacular reputation.
Should be fine. I have never had oil leaks from switching to synthetic. I have switched every vehicle I have owned in the last 10 years,the least mileage was 80,000 miles,never had a leak.
Old 07-26-2014, 12:19 AM
krooser's Avatar
krooser krooser is offline
krooser is gaining momentum as a positive member of FTE.
I switched to Mobil 1 on my E-350 @ 105,000 miles. Sold it 18 months later with 385,000 miles and all was well.
Old 07-26-2014, 12:32 AM
jasoncarpenter1's Avatar
jasoncarpenter1 jasoncarpenter1 is offline
jasoncarpenter1 is gaining momentum as a positive member of FTE.
I hear Amsoil is the best...........
Old 07-26-2014, 12:50 AM
krooser's Avatar
Quote:
I was an Amsoil dealer in the 70's great product then and now.
Old 07-26-2014, 06:45 AM
blkF250HD's Avatar
blkF250HD blkF250HD is offline
blkF250HD is gaining momentum as a positive member of FTE.blkF250HD is gaining momentum as a positive member of FTE.
Quote:
He's referring to another thread in this section that got locked due to relentless spamming by another member here claiming that Amsoil will cure cancer, save the rainforests, and eliminate burnt toast.
OP- these trucks were designed with conventional in mind, run whatever you like (selecting a name brand is a good idea) and just ensure the level is correct at all times.
Old 07-26-2014, 08:07 AM
Quote:
It has been proven that Synthetic will leak where dino does not.
Did the van not shut off in those 18 months? Hell, i don't know of over the road trucks that put 15,000 miles on a MONTH or 518 miles a DAY for a year and a half straight
Old 07-26-2014, 08:57 AM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
i use regular oil.
i also will not use synthetic in a vehicle that was not designed for it.
my 02 went in for a trans fluid change. i specifically told them regular trans fluid. they put synthetic in it.
i refused to pay for the synthetic, because i told them not to use it.
3 days later i was back with trans low fluid .
and 3 days later again. and 3 days later again. after 4 times filling the trans up, they drained the synthetic out and replaced it with regular mercon.
that was 24,000 miles ago, and i have only put 3 quarts in it, all within the first 500 miles.
Old 07-26-2014, 09:13 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
i run the mobil 1 5w 40 diesel oil in my trucks.it's good oil.i change every 9k miles using their extra large filters.
iv never experienced oil leaks due to the type of oil iv used.iv had plenty of oil leaks over the years in various cars/trucks but iv never blamed it on the dino oil lol.if you've got a oil leak,then replace the gasket/seal so it doesn't leak anymore with any type of lube is what id recommend.
Old 07-26-2014, 04:01 PM
i ain't rite
i am not blaming the leak on dino oil, i am blaming it on synthetic.
i have seen it way to many times.
put synthetic in the engine or trans, and it leaks out of everyplace.
switch back to regular oil, and no more leaks.
Old 07-26-2014, 04:08 PM
BruteFord BruteFord is offline
BruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud ofBruteFord has much to be proud of
Synthetic will tend to leak more, but so what, it's still worth the other benefits. IDK about your trucks but mine doesn't leak oil, it has an advanced undercarriage coating system.
Old 07-26-2014, 04:15 PM
timbersteel's Avatar
timbersteel timbersteel is online now
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
LOL!! "An advanced undercarriage coating system!!""
No rust here either!
Old 07-26-2014, 04:31 PM
i ain't rite
advanced undercarriage protection system does not work when a customer comes into the shop complaining about an oil leak though.
first thing i always asked was "did you switch to synthetic oil?" was most often followed by yup.
and after switching back to regular dino oil the leaks went away.
Old 07-26-2014, 04:36 PM
FWIW I roll synthetic in a very high mile 460 that when I bought it blew out about a qt of dino every 10 miles on the hwy on my way home after purchase. I modified the PCV system, bodda bing bodda boom no oil leaks at all with synthetic.
Mobile 1 oil filter jake22si 1997 - 2003 F150 10 09-24-2014 06:45 PM
Mobil 1 Oil Filter?? Supercab 1999 - 2003 7.3L Power Stroke Diesel 1 07-20-2014 08:00 AM
Mobil 1 synthetic oil change intervals changoo 2004 - 2008 F150 11 12-04-2010 07:25 PM
Mobil1 vs Motorcraft Semi Syn - Poll? rustyfuryiii Modular V10 (6.8l) 30 11-24-2006 05:49 PM
is this normal ? Mobil one oil YOMAN Oil & Lubrication 8 09-29-2005 01:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
