Vapor Canister Vent Solenoid - Ford Truck Enthusiasts Forums
Old 07-25-2014, 06:58 PM
garry11268 garry11268 is offline
garry11268 is starting off with a positive reputation.
Does anyone know where is the sensor for a 2006 Ford F150 5.4 Vapor Canister Vent Solenoid is located?
Old 07-26-2014, 01:41 AM
j.grif's Avatar
j.grif j.grif is offline
j.grif has a very good reputation on FTE.j.grif has a very good reputation on FTE.j.grif has a very good reputation on FTE.j.grif has a very good reputation on FTE.
I would think that it would be mounted on the canister itself, but it may be under the hood attached to one of the vacuum lines going into the intake, it may be located on the fire wall and possibly be called out on the vacuum hose diagram if Ford put the sticker under the hood, sorry I couldn't be more specific, You may get more answers in the 2004-2008 forum, good luck!
Old 07-26-2014, 08:45 AM
Thank you very much. I will check under the hood and also post on 2004-2008 forum. Garry...
Old 07-26-2014, 10:40 AM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
The vent solenoid is mounted in the canister above the spare tire. The purge valve is under the hood next to the brake booster.
Old 07-26-2014, 11:43 AM
Thanks, if of them is malfunctioning would that be the reason the check engine light is on? I had it checked by a garage they said it was a sensor related to my gas tank vent.
Old 07-26-2014, 01:06 PM
What is the code?
Old 07-26-2014, 01:36 PM
Took to Advance and the code was 0446. Thanks for your help..
Slow refueling '05 Expy Skauber 1997-2006 Expedition & Navigator 25 10-05-2016 07:24 AM
Vapor Canister Purge Solenoid clicking pontala 1987 - 1996 F150 & Larger F-Series Trucks 0 02-20-2016 12:03 AM
Charcoal Vapor Canister Delete 05victorylly 1987 - 1996 F150 & Larger F-Series Trucks 24 12-19-2015 07:30 PM
Vapor Canister Purge Solenoid RIKIL 1987 - 1996 F150 & Larger F-Series Trucks 3 11-23-2014 02:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
