Gaskets for Sterling 10.5. & Dana 50 - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 07-25-2014, 05:42 PM
miko6810's Avatar
miko6810 miko6810 is offline
Hand of the King
miko6810 has a very good reputation on FTE.miko6810 has a very good reputation on FTE.miko6810 has a very good reputation on FTE.
I ordered one of those aluminum diff covers and being of a time when "you used a gasket" I did some looking around on the interwebs and found Quad4x4 that sells gasket's for our Excursions.
QU40367 DANA 60/70 DIFF GASKET $10.09
QU40400 REAR DIFF GASKET $14.05
https://www.quad4x4.com
I'll probably use a small amount of RTV to set it in place, but I thought I would share the info..
Old 07-25-2014, 05:49 PM
Romanova's Avatar
Romanova Romanova is offline
Romanova has a great reputation on FTE.Romanova has a great reputation on FTE.Romanova has a great reputation on FTE.Romanova has a great reputation on FTE.
Did you get the appropriate hardware for the rear diff cover?
Honestly, I think most people just use RTV and don't have any problems. I just did mine this past weekend and used RTV... no issues.
Old 07-25-2014, 05:51 PM
miko6810's Avatar
Hand of the King
I did order the longer bolts, ( not from ford ) because some bean counter at ford has issues! $8 a bolt? Yeaa okay...
Old 07-25-2014, 05:56 PM
Romanova's Avatar
Make sure you get the washers too. If you didn't, PM me... still have some left over... minimum order of 50 when I got them lol
Old 07-26-2014, 06:37 AM
leftfinsright leftfinsright is offline
leftfinsright is starting off with a positive reputation.
I would skip the pre-made felt gasket entirely. I have changed the diff fluid in my Ex twice and used Permatex's gear oil RTV both times. They make an RTV specific for the differential (Permatex part 81182). A 3 oz. tube is about $9. I have had good luck with it; no leaks.
Gasket Makers : Permatex® Gear Oil RTV Gasket Maker
I also used the Royal Purple 75-140W syn for rear fluid. Its a little pricey but it has the friction modifier already mixed. Good luck.
Old 07-26-2014, 07:18 AM
WE3ZS's Avatar
WE3ZS WE3ZS is offline
World Famous Mod
WE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputation
Reusable gaskets.
I bought the Lube Locker reusable gaskets for my axles when I bought the new housings with 4.88 gears and added the '08 SD aluminum cover.
They cost more than a tube of RTV but they can be used over and over so maybe in the end it's a push on the cost. No leaks so far with lots of heavy towing. LubeLocker - LubeLocker Ford/Sterling 10.25"/10.5" and for the Dana 50 up front LubeLocker - LubeLocker Dana 60
Old 07-26-2014, 11:53 AM
miko6810's Avatar
Hand of the King
Well, I just cancelled my order with quad and got a set of these lube lockers!
Thanks!
Old 07-26-2014, 01:57 PM
WE3ZS's Avatar
World Famous Mod
Good luck with them!
Take some pictures, I forgot to when I installed mine.
Old 07-26-2014, 08:35 PM
miko6810's Avatar
Hand of the King
I'd like to replace the bolts on the front cover, can anybody tell me what size they are?
Old 01-15-2015, 09:29 PM
2000EX4X4LTD 2000EX4X4LTD is offline
2000EX4X4LTD is starting off with a positive reputation.
I'd also like to know what size bolts to get for a 2000 Excursion v10 4x4.
Old 01-15-2015, 10:16 PM
WE3ZS's Avatar
World Famous Mod
Quote:
For the front Dana 50 with a stock steel cover they should be 3/8-16 x 3/4" and for the rear Sterling 10.5 with a stock steel cover 5/16-18 x 1" and if using the '08 finned aluminum cover discussed above the bolts need to be 5/16-18 x 1 1/4" (with matching washers). I used allen head stainless cap screws and washers on my alum rear cover to keep it looking snazzy.
Old 01-15-2015, 10:33 PM
Quote:
Thanks - that's a big help. I'm looking into these front and rear covers from cfrperformance:
1986-UP FORD STERLING (F-250-F-350-EXCURSION) CHROME STEEL REAR DIFFERENTIAL COVER - 12 BOLT W/ 10.5" RING GEAR
Do you know if the standard bolt sizes you mentioned would suffice?
Old 01-15-2015, 10:37 PM
WE3ZS's Avatar
World Famous Mod
With them being the stock style (with chrome) steel covers the bolt sizes given above should work fine, use the shorter ones for the rear as the alum covers are a little thicker.
Parts found on Dana 44 WW2N 1973 - 1979 F-100 & Larger F-Series Trucks 0 11-05-2015 09:14 PM
76 F250 DIFFERENTIAL QUESTION VaFordman26 1973 - 1979 F-100 & Larger F-Series Trucks 3 09-09-2013 11:27 PM
Rear Axle Vent Fitting ikkaruss 1987 - 1996 F150 & Larger F-Series Trucks 6 02-01-2013 09:45 AM
Spindle Lock nut for 97 F250 rsstansbury 1999 to 2016 Super Duty 0 09-26-2012 10:03 PM
Drive shaft help heartnurse73 Excursion - King of SUVs 0 06-29-2012 06:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
